Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement
  1. Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement, Rear Case: step 1, image 1 of 3 Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement, Rear Case: step 1, image 2 of 3 Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement, Rear Case: step 1, image 3 of 3
    • Before disassembling your Samsung Galaxy Tab 4 8.0, be sure it is powered off and you remove the SIM and MicroSD cards
    • At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
    • Do not use excessive force when prying the clips, fastening the casing together, open because they can easily break.
  2. Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement: step 2, image 1 of 2 Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement: step 2, image 2 of 2
    • Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
    • As right-handers, we found it easiest to move clockwise and use more pressure around the corners to facilitate the process.
    • You might hear several popping noises caused by the plastic clips coming undone.
  3. Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement: step 3, image 1 of 2 Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement: step 3, image 2 of 2
    • To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
    • Firmly grasp the back plastic casing and lift it away from the front assembly panel.
Ofelia Cruz
1,119 Reputation
5 Guides authored
CSU Fullerton, Team 1-3, Bruce Fall 2015 Member of CSU Fullerton, Team 1-3, Bruce Fall 2015
CSUF-BRUCE-F15S1G3
4 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 10
All Time: 901
