Samsung Galaxy SIII Mini Camera failed Replacement
Video Overview
  1. Samsung Galaxy SIII Mini Camera failed Replacement, Camera Data and Cache: step 1, image 1 of 3 Samsung Galaxy SIII Mini Camera failed Replacement, Camera Data and Cache: step 1, image 2 of 3 Samsung Galaxy SIII Mini Camera failed Replacement, Camera Data and Cache: step 1, image 3 of 3
    • Go to:
    • > Settings
    • > Application manager
    • > All
    • >Camera
    • Clear data and cache and check that the camera works. If no, go to the next step.
  2. Samsung Galaxy SIII Mini Camera failed Replacement, Factory / Hard Reset: step 2, image 1 of 3 Samsung Galaxy SIII Mini Camera failed Replacement, Factory / Hard Reset: step 2, image 2 of 3 Samsung Galaxy SIII Mini Camera failed Replacement, Factory / Hard Reset: step 2, image 3 of 3
    • Go to:
    • > Settings > Backup and reset
    • > Factory data reset
    • > Reset device > Erase everithing
    • !!! This will erase all your data !!!
    • For a Hard reset using hardware keys, follow this manual:
    • Samsung Galaxy - Wipe data/Factory reset
  3. Samsung Galaxy SIII Mini Camera failed Replacement, Firmware: step 3, image 1 of 3 Samsung Galaxy SIII Mini Camera failed Replacement, Firmware: step 3, image 2 of 3 Samsung Galaxy SIII Mini Camera failed Replacement, Firmware: step 3, image 3 of 3
    • Open sammobile and make an registration.
    • Search the firmware for your model and find the variant, corresponding to your mobile phone.
    • You can see the variant from Settings > About the device, or from dialer app by entering *#1234#
    • In the download page you can find instructions and link to the Odin app.
  4. Samsung Galaxy SIII Mini Camera failed Replacement, Reconnecting Camera: step 4, image 1 of 3 Samsung Galaxy SIII Mini Camera failed Replacement, Reconnecting Camera: step 4, image 2 of 3 Samsung Galaxy SIII Mini Camera failed Replacement, Reconnecting Camera: step 4, image 3 of 3
    • Switch off the phone and remove the battery and any SIM and memory card.
    • Remove the Midframe.
    • Disconnect the Menu buttons and the SD card reader flex cables.
    • Lift the board slightly to the left side and be careful with the earpiece and the main camera - they are stuck to the Display frame.
  5. Samsung Galaxy SIII Mini Camera failed Replacement: step 5, image 1 of 3 Samsung Galaxy SIII Mini Camera failed Replacement: step 5, image 2 of 3 Samsung Galaxy SIII Mini Camera failed Replacement: step 5, image 3 of 3
    • Disconnect the LCD Display flex cable.
    • Open the camera flex cable connector and reconnect the camera.
  6. Samsung Galaxy SIII Mini Camera failed Replacement, Camera Replacement: step 6, image 1 of 3 Samsung Galaxy SIII Mini Camera failed Replacement, Camera Replacement: step 6, image 2 of 3 Samsung Galaxy SIII Mini Camera failed Replacement, Camera Replacement: step 6, image 3 of 3
    • If the camera still does not work, the last step is camera replacement.
  7. Samsung Galaxy SIII Mini Camera failed Replacement: step 7, image 1 of 1
    • Did you do it successfully?
ZFix
191,368 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,545 Guides authored
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 22
All Time: 9,567
