Samsung Galaxy S4 Active I537 Charging port Replacement
  1. Samsung Galaxy S4 Active I537 Charging port Replacement, Rear Cover: step 1, image 1 of 2 Samsung Galaxy S4 Active I537 Charging port Replacement, Rear Cover: step 1, image 2 of 2
    • Remove back cover
    • Remove battery
  2. Samsung Galaxy S4 Active I537 Charging port Replacement, remove screws: step 2, image 1 of 1
    • remove battery before taking off screws
    • remove the 8 screws in the back using a small Phillips screw driver
  3. Samsung Galaxy S4 Active I537 Charging port Replacement, Covers: step 3, image 1 of 1
    • using a prying tool or something remove the 4 covers that are blocking the last 4 screws
    • you might have to put a bit of pressure to get them off
  4. Samsung Galaxy S4 Active I537 Charging port Replacement, More screws: step 4, image 1 of 2 Samsung Galaxy S4 Active I537 Charging port Replacement, More screws: step 4, image 2 of 2
    • Remove the 4 screws
    • with a prying tool or fingers go around the edges to remove the plastic back part of the phone
    • be carefull not to break it by using too much force
  5. Samsung Galaxy S4 Active I537 Charging port Replacement, Screws: step 5, image 1 of 1
    • Remove these 2 screws then take off the white plastic part
  6. Samsung Galaxy S4 Active I537 Charging port Replacement, Antenna cable: step 6, image 1 of 1
    • use prying tool or finger to unplug antenna cable
    • be extra careful unplugging this
  7. Samsung Galaxy S4 Active I537 Charging port Replacement: step 7, image 1 of 1
    • use prying tool or fingers to unplug this connection
    • again be careful
  8. Samsung Galaxy S4 Active I537 Charging port Replacement: step 8, image 1 of 2 Samsung Galaxy S4 Active I537 Charging port Replacement: step 8, image 2 of 2
    • you can now use the prying tool or fingers to remove the charging port and replace it with the new one
    • follow steps in reverse to resemble
    • carefully
ted582 ted583
529 Reputation
1 Guide authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 7,860
