Samsung Galaxy S10e Midframe Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Samsung Galaxy S10e Midframe Replacement, Midframe: step 1, image 1 of 1
    • Remove the eight 3.9 mm Phillips screws securing the upper midframe to the phone.
  2. Samsung Galaxy S10e Midframe Replacement: step 2, image 1 of 2 Samsung Galaxy S10e Midframe Replacement: step 2, image 2 of 2
    • Slide an opening pick under the bottom right corner of the upper midframe to separate the adhesive holding it to the lower midframe.
  3. Samsung Galaxy S10e Midframe Replacement: step 3, image 1 of 2 Samsung Galaxy S10e Midframe Replacement: step 3, image 2 of 2
    • Insert the point of a spudger in the small cutout on the right edge of the plastic part of the upper midframe, near the Bixby button.
    • Use the point of the spudger to pry the midframe up from the phone chassis.
  4. Samsung Galaxy S10e Midframe Replacement: step 4, image 1 of 1
    • Lift the midframe by the plastic section and remove it from the phone.
    • To reinstall, first insert the top edge of the assembly into the phone's frame, and then gently press down on the rest of the assembly to snap it into place.
Adam O'Camb
197,111 Reputation
416 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 146
