Samsung Galaxy S II Front Glass/Digitizer Replacement
Video Overview
  1. Samsung Galaxy S II Front Glass/Digitizer Replacement, Front Glass and Digitizer: step 1, image 1 of 2 Samsung Galaxy S II Front Glass/Digitizer Replacement, Front Glass and Digitizer: step 1, image 2 of 2
    • We have a Samsung Galaxy S II with broken screen.
  2. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 2, image 1 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 2, image 2 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 2, image 3 of 3
    • Remove your battery, the SIM card and the SD card.
    • Remove the 7 screws highlighted in red.
  3. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 3, image 1 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 3, image 2 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 3, image 3 of 3
    • Use a plastic tool to remove the rear housing.
  4. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 4, image 1 of 2 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 4, image 2 of 2
    • The mother board is held by 2x screws. Remove them.
  5. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 5, image 1 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 5, image 2 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 5, image 3 of 3
    • Remove the cables that are highlighted in red, before continuing to the screen.
  6. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 6, image 1 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 6, image 2 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 6, image 3 of 3
    • Release the side buttons. The arrow will point you to where they are.
  7. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 7, image 1 of 2 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 7, image 2 of 2
    • Careful release the motherboard from it's housing.
  8. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 8, image 1 of 2 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 8, image 2 of 2
    • At this moment if you have touch screen with LCD and frame like spare part you are ready for replacing.
    • We will continue with disassembling LCD and Touch from the frame. Now preheat it before removing!
    • Use a hot air to soften the adhesive enough to remove the glass.
  9. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 9, image 1 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 9, image 2 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 9, image 3 of 3
    • With a cutter, make a room for a plastic tool, then continue with separating the Touchscreen & LCD Display from the frame.
  10. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 10, image 1 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 10, image 2 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 10, image 3 of 3
    • Be careful with the menu buttons flex cable in the bottom side of the touchscreen. You must release it before separating the digitizer from the frame.
  11. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 11, image 1 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 11, image 2 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 11, image 3 of 3
    • Now, use a suction tool to remove the screen from it's housing. Be careful when doing this, to prevent possible injury.
  12. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 12, image 1 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 12, image 2 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 12, image 3 of 3
    • Clean the frame from the remains of tape.
  13. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 13, image 1 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 13, image 2 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 13, image 3 of 3
    • Test the new spare part before reassembling.
  14. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 14, image 1 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 14, image 2 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 14, image 3 of 3
    • Install the LCD&Digitiser on it's housing.
    • Many times the spare parts come without adhesive tape. In this situation you'll need to install double sided adhesive tape yourself. Also you can easy find adhesive sticker exactly for the model.
  15. Samsung Galaxy S II Front Glass/Digitizer Replacement: step 15, image 1 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 15, image 2 of 3 Samsung Galaxy S II Front Glass/Digitizer Replacement: step 15, image 3 of 3
    • To reassemble your device, follow these instructions in reverse order.
    • Did you do it successfully?
ZFix
191,341 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,540 Guides authored
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 38
All Time: 98,628
