Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement
Video Overview
  1. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement, Rear camera & front camera & eapiece: step 1, image 1 of 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement, Rear camera & front camera & eapiece: step 1, image 2 of 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement, Rear camera & front camera & eapiece: step 1, image 3 of 3
    • Remove SIM card tray.
  2. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 2, image 1 of 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 2, image 2 of 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 2, image 3 of 3
    • Remove S Pen.
  3. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 3, image 1 of 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 3, image 2 of 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 3, image 3 of 3
    • Remove back cover.
  4. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 4, image 1 of 2 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 4, image 2 of 2
    • Remove screws.
  5. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 5, image 1 of 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 5, image 2 of 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 5, image 3 of 3
    • Remove middle housing.
  6. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 6, image 1 of 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 6, image 2 of 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 6, image 3 of 3
    • Remove battery. But it's not necessary. You also can just release battery connector from motherboard.
  7. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 7, image 1 of 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 7, image 2 of 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 7, image 3 of 3
    • Release the connector on the board.
  8. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 8, image 1 of 2 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 8, image 2 of 2
    • Release the USB board connector on the back and remove the motherboard from front assembly.
  9. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 9, image 1 of 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 9, image 2 of 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 9, image 3 of 3
    • Remove rear camera.
  10. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 10, image 1 of 2 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 10, image 2 of 2
    • Remove front camera and noise-canceling mic.
  11. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 11, image 1 of 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 11, image 2 of 3 Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 11, image 3 of 3
    • Remove earpiece assembly.
  12. Samsung Galaxy Note5 rear camera & front camera & earpiece Replacement: step 12, image 1 of 1
    • That's earpiece with sensors.
12 other people completed this guide.
Sophia
43,810 Reputation
62 Guides authored
9 Comments
Is there a way to replace the rear camera glass without remove the back cover?
Steve Tran - Reply
Steve, I'm not sure if anyone told you yet, but yes. Using some pointed tweezers (CAREFULLY) you can pull the glass off. But, be very careful as the housing holding the glass can be damaged due to the tweezers.
Kelby -
Will the phone be able to operate as usual without both the rear and front camera?
Sean - Reply
I accidently fell my phone into the water n my front camera is enter some water.Then ,I try to dry it by my hair dryer but my front camera is cover by distilled water.The front camera is working but it is blurry. How can I fix it?
jianshenphoon - Reply
Please anyone, I have the same problem. Front cam is covered with oil. Any suggestion?
zerry yns -
Hi. When i installed new camera it said that the camera failed. Any solution?
Ameer Yusrie - Reply
Hi Sophia, can I replace my n920T camera with another version of galnote 5? Let’s say N920?
Please help. My email is septian.nuryanto@gmail.com.
Thanks
Septian N - Reply
Hi Sophia, can I replace my n920T rear camera with another version of galnote, let’s say N920.
Will it operate normally?
Please help, my email is septian.nuryanto@gmail.com
Thanks.
Septian N - Reply
My Note 5 has a broken back camera glass on the cover. It still takes photos, albeit not so sharp. If I just replace the glass, will it sharpen up? CAN I just replace the glass?
Thanks,
Ron Smith - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 9
All Time: 20,167
