Samsung Galaxy Note10 Screen Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Video Overview
    1. Samsung Galaxy Note10 Screen Replacement, Screen: step 1, image 1 of 2 Samsung Galaxy Note10 Screen Replacement, Screen: step 1, image 2 of 2
      • Test to see if phone is functional
      • Force Shut Down Device
      • Hold power button and volume down button for 7 seconds! Any longer it will restart.
      • Apply Heat to Back Glass
      • Should be to hot to touch
      Ask FixBot
    2. Samsung Galaxy Note10 Screen Replacement: step 2, image 1 of 3 Samsung Galaxy Note10 Screen Replacement: step 2, image 2 of 3 Samsung Galaxy Note10 Screen Replacement: step 2, image 3 of 3
      • Use suction cup on bottom 1st use metal pry tool to make enough room for guitar pick.
      • Rotate guitar pick around edges.
      • Wiggle back glass with suction cup. Use your hand to lift one edge.
      • Note10 Edges are more curved than previous note models and also curve around volume/side buttons
      • Do not recommend using metal pry tool you will most likely break it the backglass
      Ask FixBot
    3. Samsung Galaxy Note10 Screen Replacement: step 3, image 1 of 1
      • Remove PH000 14 Screws
      • Start From the top removing wireless charger pad.
      Ask FixBot
    4. Samsung Galaxy Note10 Screen Replacement: step 4, image 1 of 2 Samsung Galaxy Note10 Screen Replacement: step 4, image 2 of 2
      • Pry from the top and slide upward to remove plastic protector
      • Remove from the top down!
      Ask FixBot
    5. Samsung Galaxy Note10 Screen Replacement: step 5, image 1 of 3 Samsung Galaxy Note10 Screen Replacement: step 5, image 2 of 3 Samsung Galaxy Note10 Screen Replacement: step 5, image 3 of 3
      • Fold down metal bracket of wireless charging pad
      • Disconnect Battery Connector
      • Remove Wireless charging Pad connection. (BLACK FLEX)
      • Lift upward wiggling off the side adhesive and you will pull up the bottom plastic protector
      Ask FixBot
    6. Samsung Galaxy Note10 Screen Replacement: step 6, image 1 of 3 Samsung Galaxy Note10 Screen Replacement: step 6, image 2 of 3 Samsung Galaxy Note10 Screen Replacement: step 6, image 3 of 3
      • 3 PH000 Screws
      • Disconnect front camera, and 2 flexs cables marked in blue put off to the side.
      • Disconnect everything marked in Yellow or Blue
      • Sim Card Tray and Stylus should be removed as well before moving boards!
      Ask FixBot
    7. Samsung Galaxy Note10 Screen Replacement: step 7, image 1 of 2 Samsung Galaxy Note10 Screen Replacement: step 7, image 2 of 2
      • Pry with spudger Main Board from the top down gently lift board.
      • At an angle lift board upward with your free hand
      Ask FixBot
    8. Samsung Galaxy Note10 Screen Replacement: step 8, image 1 of 3 Samsung Galaxy Note10 Screen Replacement: step 8, image 2 of 3 Samsung Galaxy Note10 Screen Replacement: step 8, image 3 of 3
      • Unscrew 3 PH000 Screws
      • With spudger lift top of charging port
      • Lift from the top of charging port moving towards the left
      Ask FixBot
    9. Samsung Galaxy Note10 Screen Replacement: step 9, image 1 of 2 Samsung Galaxy Note10 Screen Replacement: step 9, image 2 of 2
      • Use heat gun warm up battery adhesive pry from the bottom up with plastic spudger
      • Lift from bottom up
      • Do not rip battery out you will deform it
      Ask FixBot
    10. Samsung Galaxy Note10 Screen Replacement: step 10, image 1 of 3 Samsung Galaxy Note10 Screen Replacement: step 10, image 2 of 3 Samsung Galaxy Note10 Screen Replacement: step 10, image 3 of 3
      • Place charging port daughter board in new screen assembly
      • Screw Down PH000 Screws
      • Then place the Main board
      • Connect all flex cables
      • Connect battery with adhesive and place battery to ensure it connects and seats correctly
      Ask FixBot
    11. Samsung Galaxy Note10 Screen Replacement: step 11, image 1 of 3 Samsung Galaxy Note10 Screen Replacement: step 11, image 2 of 3 Samsung Galaxy Note10 Screen Replacement: step 11, image 3 of 3
      • Connect all the flex cables
      • Place Charging pad and plastic protectors
      • Don't screw everything down complete until after you test the screen
      Ask FixBot
      • Check your work place back glass with new adhesive
      Ask FixBot
Mark D Schlossman
8,126 Reputation
13 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 11
All Time: 134
