Samsung Galaxy Note II Motherboard Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Samsung Galaxy Note II Motherboard Assembly Replacement, Motherboard Assembly: step 1, image 1 of 3 Samsung Galaxy Note II Motherboard Assembly Replacement, Motherboard Assembly: step 1, image 2 of 3 Samsung Galaxy Note II Motherboard Assembly Replacement, Motherboard Assembly: step 1, image 3 of 3
    • Use a spudger to disconnect the vibrator/power button assembly cable connector.
    • Disconnect the antenna cable connector.
    • Disconnect the display cable connector.
  2. Samsung Galaxy Note II Motherboard Assembly Replacement: step 2, image 1 of 3 Samsung Galaxy Note II Motherboard Assembly Replacement: step 2, image 2 of 3 Samsung Galaxy Note II Motherboard Assembly Replacement: step 2, image 3 of 3
    • Disconnect the front-facing camera cable connector.
    • Disconnect the headphone jack cable connector.
    • Disconnect the digitizer cable connector.
  3. Samsung Galaxy Note II Motherboard Assembly Replacement: step 3, image 1 of 3 Samsung Galaxy Note II Motherboard Assembly Replacement: step 3, image 2 of 3 Samsung Galaxy Note II Motherboard Assembly Replacement: step 3, image 3 of 3
    • Use the spudger to disconnect the antenna cable connector from the motherboard.
    • Disconnect the soft button cable connector.
    • Disconnect the USB board cable connector.
  4. Samsung Galaxy Note II Motherboard Assembly Replacement: step 4, image 1 of 1
    • Remove the 3 mm Phillips #00 screw securing the motherboard to the display assembly.
  5. Samsung Galaxy Note II Motherboard Assembly Replacement: step 5, image 1 of 2 Samsung Galaxy Note II Motherboard Assembly Replacement: step 5, image 2 of 2
    • Gently remove the motherboard.
    • Hold the motherboard by its edges to prevent ESD damage. Be careful not to snag it on any cables as you extract it from the display assembly.
Sam Goldheart
466,174 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 57
