Replacing Samsung Galaxy Note II Motherboard Assembly
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Replacing Samsung Galaxy Note II Motherboard Assembly, Motherboard Assembly: step 1, image 1 of 3 Replacing Samsung Galaxy Note II Motherboard Assembly, Motherboard Assembly: step 1, image 2 of 3 Replacing Samsung Galaxy Note II Motherboard Assembly, Motherboard Assembly: step 1, image 3 of 3
    • Use a spudger to disconnect the vibrator/power button assembly cable connector.
    • Disconnect the antenna cable connector.
    • Disconnect the display cable connector.
  2. Replacing Samsung Galaxy Note II Motherboard Assembly: step 2, image 1 of 3 Replacing Samsung Galaxy Note II Motherboard Assembly: step 2, image 2 of 3 Replacing Samsung Galaxy Note II Motherboard Assembly: step 2, image 3 of 3
    • Disconnect the front-facing camera cable connector.
    • Disconnect the headphone jack cable connector.
    • Disconnect the digitizer cable connector.
  3. Replacing Samsung Galaxy Note II Motherboard Assembly: step 3, image 1 of 3 Replacing Samsung Galaxy Note II Motherboard Assembly: step 3, image 2 of 3 Replacing Samsung Galaxy Note II Motherboard Assembly: step 3, image 3 of 3
    • Use the spudger to disconnect the antenna cable connector from the motherboard.
    • Disconnect the soft button cable connector.
    • Disconnect the USB board cable connector.
  4. Replacing Samsung Galaxy Note II Motherboard Assembly: step 4, image 1 of 1
    • Remove the 3 mm Phillips #00 screw securing the motherboard to the display assembly.
  5. Replacing Samsung Galaxy Note II Motherboard Assembly: step 5, image 1 of 2 Replacing Samsung Galaxy Note II Motherboard Assembly: step 5, image 2 of 2
    • Gently remove the motherboard.
    • Hold the motherboard by its edges to prevent ESD damage. Be careful not to snag it on any cables as you extract it from the display assembly.
Sam Goldheart
466,490 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,524 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 57
