Samsung Galaxy J3 Luna Pro Motherboard Change Replacement
  1. Samsung Galaxy J3 Luna Pro Motherboard Change Replacement, Motherboard Change: step 1, image 1 of 1
    • Turn off the phone.
    • Remove the back cover and battery
  2. Samsung Galaxy J3 Luna Pro Motherboard Change Replacement: step 2, image 1 of 3 Samsung Galaxy J3 Luna Pro Motherboard Change Replacement: step 2, image 2 of 3 Samsung Galaxy J3 Luna Pro Motherboard Change Replacement: step 2, image 3 of 3
    • Attach a suction cup to the screen and pry upwards.
    • Insert the plastic opening tool into the gap under the screen and work your way around the perimeter.
    • Don't remove the screen completely as there are cables still connection the two pieces.
  3. Samsung Galaxy J3 Luna Pro Motherboard Change Replacement: step 3, image 1 of 3 Samsung Galaxy J3 Luna Pro Motherboard Change Replacement: step 3, image 2 of 3 Samsung Galaxy J3 Luna Pro Motherboard Change Replacement: step 3, image 3 of 3
    • Use the pointy end of a spudger to remove the white plastic cover from the display cover.
    • Use the spudger to pry up the display cable from the motherboard.
    • Remove the screen.
  4. Samsung Galaxy J3 Luna Pro Motherboard Change Replacement: step 4, image 1 of 3 Samsung Galaxy J3 Luna Pro Motherboard Change Replacement: step 4, image 2 of 3 Samsung Galaxy J3 Luna Pro Motherboard Change Replacement: step 4, image 3 of 3
    • Remove the eleven JIS #00 screws from the mid-frame.
    • Using a spudger, pry the mid-frame from the screen.
  5. Samsung Galaxy J3 Luna Pro Motherboard Change Replacement: step 5, image 1 of 3 Samsung Galaxy J3 Luna Pro Motherboard Change Replacement: step 5, image 2 of 3 Samsung Galaxy J3 Luna Pro Motherboard Change Replacement: step 5, image 3 of 3
    • Gently take off the motherboard.
    • It should come off easily, if not something may still be connected.
shima1h
185 Reputation
1 Guide authored
USF Tampa, Team S5-G5, Passmore Spring 2018 Member of USF Tampa, Team S5-G5, Passmore Spring 2018
USFT-PASSMORE-S18S5G5
5 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 2,912
