Samsung Galaxy A5 (2016) Back Cover Replacement
  1. Samsung Galaxy A5 (2016) Back Cover Replacement, Back Cover: step 1, image 1 of 3 Samsung Galaxy A5 (2016) Back Cover Replacement, Back Cover: step 1, image 2 of 3 Samsung Galaxy A5 (2016) Back Cover Replacement, Back Cover: step 1, image 3 of 3
    • Start by switching off your phone.
    • Take an iOpener to heat up and soften the glue behind the back cover.
    • With a suction handle lift the back cover to insert an opening pick.
  2. Samsung Galaxy A5 (2016) Back Cover Replacement: step 2, image 1 of 3 Samsung Galaxy A5 (2016) Back Cover Replacement: step 2, image 2 of 3 Samsung Galaxy A5 (2016) Back Cover Replacement: step 2, image 3 of 3
    • Slide the pick up to the middle to separate the back cover from the frame.
    • Insert a second opening pick and move around the right corner along the bottom and around the left corner.
  3. Samsung Galaxy A5 (2016) Back Cover Replacement: step 3, image 1 of 3 Samsung Galaxy A5 (2016) Back Cover Replacement: step 3, image 2 of 3 Samsung Galaxy A5 (2016) Back Cover Replacement: step 3, image 3 of 3
    • Take another opening pick and continue towards the top corner.
    • Here you want to use one more pick for the last part at the top.
  4. Samsung Galaxy A5 (2016) Back Cover Replacement: step 4, image 1 of 3 Samsung Galaxy A5 (2016) Back Cover Replacement: step 4, image 2 of 3 Samsung Galaxy A5 (2016) Back Cover Replacement: step 4, image 3 of 3
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Insert a plastic card at the bottom and slide it underneath the back cover.
  5. Samsung Galaxy A5 (2016) Back Cover Replacement: step 5, image 1 of 3 Samsung Galaxy A5 (2016) Back Cover Replacement: step 5, image 2 of 3 Samsung Galaxy A5 (2016) Back Cover Replacement: step 5, image 3 of 3
    • Heat up the back cover once again so you can slide the plastic card towards the top.
    • Always take a peek underneath the back cover to not damage any parts like the NFC antenna.
    • Move the plastic card until you reach the camera bump. Now slowly lift up the back cover and finally remove it.
    • Be sure to remove any residue from the glue and apply new adhesive when reassembling.
24 other people completed this guide.
Tobias Isakeit
117,598 Reputation
188 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,535 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 40
All Time: 48,294
