Introduction
You will need to find a clean area to work in and have the necessary tools. Follow this guide to gain access to your cellphone's motherboard.
Continuing to use the Phillips #00 screwdriver, gently pry the silver plastic back plate from the body of the phone.
Slightly pull up one side of the motherboard.
Pull the button/microphone plug out of its socket.
Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
