Samsung Eternity Motherboard Replacement
    • Remove the back battery cover.
  1. Samsung Eternity Motherboard Replacement: step 2, image 1 of 1
    • Using the Phillips #00 screwdriver, remove the phone's battery.
  2. Samsung Eternity Motherboard Replacement: step 3, image 1 of 1
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver
  3. Samsung Eternity Motherboard Replacement: step 4, image 1 of 2 Samsung Eternity Motherboard Replacement: step 4, image 2 of 2
    • Continuing to use the Phillips #00 screwdriver, gently pry the silver plastic back plate from the body of the phone.
  4. Samsung Eternity Motherboard Replacement, Motherboard: step 5, image 1 of 1
    • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
    • Pull the antenna plug out of its socket.
  5. Samsung Eternity Motherboard Replacement: step 6, image 1 of 3 Samsung Eternity Motherboard Replacement: step 6, image 2 of 3 Samsung Eternity Motherboard Replacement: step 6, image 3 of 3
    • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
  6. Samsung Eternity Motherboard Replacement: step 7, image 1 of 1
    • Pop the red hinged-release lever away from its ribbon. Then pull it out.
  7. Samsung Eternity Motherboard Replacement: step 8, image 1 of 1
    • Peel the button sensor on the side of the motherboard off of the case.
  8. Samsung Eternity Motherboard Replacement: step 9, image 1 of 3 Samsung Eternity Motherboard Replacement: step 9, image 2 of 3 Samsung Eternity Motherboard Replacement: step 9, image 3 of 3
    • Slightly pull up one side of the motherboard.
    • Pull the button/microphone plug out of its socket.
    • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
  9. Samsung Eternity Motherboard Replacement: step 10, image 1 of 1
    • You have successfully removed the motherboard from the phone.
Kevin Huang
11 Reputation
1 Guide authored
Cal Poly, Team 15-11, Regan Spring 2011 Member of Cal Poly, Team 15-11, Regan Spring 2011
CPSU-REGAN-S11S15G11
5 Members
14 Guides authored
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 12
All Time: 2,315
