Introduction
Use this guide to replace the back phone case and to remove the casing to access the inside of the phone.
Hold the device with the screen facing away from you and the camera towards you.
Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
Place your fingers on both sides of the bottom of the battery and lift upwards.
Pull the battery away from the phone.
Use the spudger to remove the rubber stoppers from the top of the cover.
Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
Use the spudger to loosen and separate the front and back covers.
Pick up the back cover once loosened.
Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
