Samsung Blackjack Back Phone Casing Replacement
  1. Samsung Blackjack Back Phone Casing Replacement, Battery Cover: step 1, image 1 of 3 Samsung Blackjack Back Phone Casing Replacement, Battery Cover: step 1, image 2 of 3 Samsung Blackjack Back Phone Casing Replacement, Battery Cover: step 1, image 3 of 3
    • Hold the device with the screen facing away from you and the camera towards you.
    • Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
  2. Samsung Blackjack Back Phone Casing Replacement, Battery: step 2, image 1 of 2 Samsung Blackjack Back Phone Casing Replacement, Battery: step 2, image 2 of 2
    • Place your fingers on both sides of the bottom of the battery and lift upwards.
    • Pull the battery away from the phone.
  3. Samsung Blackjack Back Phone Casing Replacement, SIM Card: step 3, image 1 of 3 Samsung Blackjack Back Phone Casing Replacement, SIM Card: step 3, image 2 of 3 Samsung Blackjack Back Phone Casing Replacement, SIM Card: step 3, image 3 of 3
    • Place your thumb on the SIM card.
    • Slide the card out of the slot.
  4. Samsung Blackjack Back Phone Casing Replacement, Back Phone Casing: step 4, image 1 of 2 Samsung Blackjack Back Phone Casing Replacement, Back Phone Casing: step 4, image 2 of 2
    • Use the spudger to remove the rubber stoppers from the top of the cover.
    • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
  5. Samsung Blackjack Back Phone Casing Replacement: step 5, image 1 of 3 Samsung Blackjack Back Phone Casing Replacement: step 5, image 2 of 3 Samsung Blackjack Back Phone Casing Replacement: step 5, image 3 of 3
    • Use the spudger to loosen and separate the front and back covers.
    • Pick up the back cover once loosened.
    • The front and back covers will be attached to each other by a gold wire.
    • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
Kristin Manna
29 Reputation
10 Guides authored
Clemson, Team 14-4, Benson Fall 2012 Member of Clemson, Team 14-4, Benson Fall 2012
CLEM-BENSON-F12S14G4
3 Members
14 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 13
All Time: 509
