Salter Model 981 Personal Scale Cable Repair
    1. Salter Model 981 Personal Scale Cable  Repair, Open the housing: step 1, image 1 of 1
      • Turn the scale over
      • Remove the battery from the battery compartment
      • Open the 4 screws with a triangular 2.0 screwdriver
      • Lift the cover (if necessary, use a flat-blade screwdriver or spudger to help at the corners)
      • Turn the scale back to the front side and remove the top side.
      Ask FixBot
    2. Salter Model 981 Personal Scale Cable  Repair, Locate the defective cable point: step 2, image 1 of 3 Salter Model 981 Personal Scale Cable  Repair, Locate the defective cable point: step 2, image 2 of 3 Salter Model 981 Personal Scale Cable  Repair, Locate the defective cable point: step 2, image 3 of 3
      • Adhesive strips are located at the marked points, under which defective cables could be located.
      • In my case the point of failure was quite obvious (marking, plus cable cut)
      • Here you can already see that these cables are also affected. If it is not so obvious, the cables should be checked for continuity.
      Ask FixBot
    3. Salter Model 981 Personal Scale Cable  Repair, Remove the old cable: step 3, image 1 of 2 Salter Model 981 Personal Scale Cable  Repair, Remove the old cable: step 3, image 2 of 2
      • use a soldering iron to desolder the old cable at the battery compartment and remove it
      • shorten the remaining cable so that the newly soldered piece is not at a breaking point (bend)
      Ask FixBot
    4. Salter Model 981 Personal Scale Cable  Repair, Strip both cable ends: step 4, image 1 of 2 Salter Model 981 Personal Scale Cable  Repair, Strip both cable ends: step 4, image 2 of 2
      • Set stripping pliers to 6mm
      • Strip the cable end of the still installed cable
      • Strip the cable end of the new cable
      Ask FixBot
    5. Salter Model 981 Personal Scale Cable  Repair, Tinning both cable ends: step 5, image 1 of 2 Salter Model 981 Personal Scale Cable  Repair, Tinning both cable ends: step 5, image 2 of 2
      • With a soldering iron and solder, tin both cable ends
      Ask FixBot
    6. Salter Model 981 Personal Scale Cable  Repair, Prepare heat shrink tubing: step 6, image 1 of 2 Salter Model 981 Personal Scale Cable  Repair, Prepare heat shrink tubing: step 6, image 2 of 2
      • Cut the 1mm heat shrink tubing 1:2 to a good length of approx. 2cm (so that the stripped contacts are covered)
      • Before soldering place the heat shrink tubing on one of the cables.
      Ask FixBot
    7. Salter Model 981 Personal Scale Cable  Repair, Soldering cable: step 7, image 1 of 1
      • Solder both tinned cable ends together
      Ask FixBot
    8. Salter Model 981 Personal Scale Cable  Repair, Insulate the solder joint: step 8, image 1 of 2 Salter Model 981 Personal Scale Cable  Repair, Insulate the solder joint: step 8, image 2 of 2
      • Move the shrink tubing over the solder joint
      • Shrink the shrink tubing with a hot air gun/hair dryer/lighter
      Ask FixBot
    9. Salter Model 981 Personal Scale Cable  Repair, Tape the cable in the housing with masking tape: step 9, image 1 of 3 Salter Model 981 Personal Scale Cable  Repair, Tape the cable in the housing with masking tape: step 9, image 2 of 3 Salter Model 981 Personal Scale Cable  Repair, Tape the cable in the housing with masking tape: step 9, image 3 of 3
      • Place the cable in its original course again
      • Secure all critical points with masking tape (except for the last bend)
      Ask FixBot
    10. Salter Model 981 Personal Scale Cable  Repair, Solder the cable to the battery contact: step 10, image 1 of 3 Salter Model 981 Personal Scale Cable  Repair, Solder the cable to the battery contact: step 10, image 2 of 3 Salter Model 981 Personal Scale Cable  Repair, Solder the cable to the battery contact: step 10, image 3 of 3
      • Shorten cable to the correct length
      • Strip cable to 6mm with wire strippers
      • tin cable with soldering iron and soldering tin
      • solder cable to the battery contact
      • if necessary shorten soldered cable after soldering
      Ask FixBot
    11. Salter Model 981 Personal Scale Cable  Repair: step 11, image 1 of 3 Salter Model 981 Personal Scale Cable  Repair: step 11, image 2 of 3 Salter Model 981 Personal Scale Cable  Repair: step 11, image 3 of 3
      • Fasten the cable in the last bend with masking tape
      • Insert the battery into the battery compartment
      • Test the scale by activating it (pressing down on it)
      Ask FixBot
Work through the steps in reverse order to reassemble your device.
2 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
hainzy
10,942 Reputation
47 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 37
All Time: 539
