SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement
  1. SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement, Spring pot lock: step 1, image 1 of 3 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement, Spring pot lock: step 1, image 2 of 3 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement, Spring pot lock: step 1, image 3 of 3
    • Remove the lid from the pot of the SILVERCREST Monsieur Cuisine Connect before processing
    • The instructions are identical for both sides.
    • Place the pot on the work surface with the opening facing down
    • Open and remove the screw cap
  2. SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: step 2, image 1 of 1
    • Remove the Phillips head screw
  3. SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: step 3, image 1 of 3 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: step 3, image 2 of 3 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: step 3, image 3 of 3
    • The lower part is fixed, pay close attention to the order of removal.
    • Remove the cover by first pulling on the top edge.
    • Then turn the cover to the right or left out of the fixation
  4. SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: step 4, image 1 of 3 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: step 4, image 2 of 3 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: step 4, image 3 of 3
    • The springs can look different depending on their condition. Sometimes they may not even be present. Note that all spring leftover parts must be removed.
    • Place the cover with the open side up in front of you
    • Remove the first spring with a suitable tool
  5. SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: step 5, image 1 of 3 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: step 5, image 2 of 3 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: step 5, image 3 of 3
    • Remove the second spring with a pair of needle nose pliers.
  6. SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: step 6, image 1 of 3 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: step 6, image 2 of 3 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: step 6, image 3 of 3
    • Insert a new matching spring.
    • A 25mm (1inch) spring is recommended.
    • Most springs are too long. Shorten them using a pair of pliers.
  7. SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: step 7, image 1 of 2 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: step 7, image 2 of 2
    • Attach the second smaller spring with the Phillips head screw
    • The correct size of this spring is vital!. The lock must be completely withdrawn in normal condition.
    • Recommendation here is a 5mm spring
  8. SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: step 8, image 1 of 2 SILVERCREST Monsieur Cuisine Connect SKMC 1200 Spring Pot Lock replacement: step 8, image 2 of 2
    • Attach the other end of the spring to the movable part of the locking mechanism
6 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Alex
307 Reputation
1 Guide authored
7 Comments
Vielen Dank! ? Monsi lebt wieder. ??
Vanessa Meinold - Reply
Super das es funktioniert hat!
Alex -
Wo bekomme ich diese Zugfedern und welche Größe benötige ich genau? Vielen Dank schon einmal
kathrin schulte - Reply
Entweder bestellst du sie online oder du versuchst es in einem Fachhandel. Der Ersteller dieser Anleitung gibt die Längen der Federn mit 5 mm und mit 25 mm an. Wenn du nur längere findest, kannst du sie theoretisch auch selbst kürzen.
Fabian Neidhardt -
Ich habe die Zugfedern in diesem Artikel mit einem Link hinterlegt. Diese müssen zum Teil mit einer Zange manuell gekürzt werden. Das ist aber relativ einfach möglich.
Alex -
Past 24 Hours: 13
Past 7 Days: 51
Past 30 Days: 282
All Time: 11,755
