SAFFUN Wireless N64 Controller Battery Replacement
    1. SAFFUN Wireless N64 Controller Battery Replacement, Back Plate: step 1, image 1 of 1
      • Before you begin, make sure the controller is disconnected and the LED indicator light is off.
      Ask FixBot
    2. SAFFUN Wireless N64 Controller Battery Replacement: step 2, image 1 of 2 SAFFUN Wireless N64 Controller Battery Replacement: step 2, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the seven 9.3 mm screws from the backplate.
      Ask FixBot
    3. SAFFUN Wireless N64 Controller Battery Replacement: step 3, image 1 of 2 SAFFUN Wireless N64 Controller Battery Replacement: step 3, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the two 9.3 mm screws.
      • Use a screwdriver with a shaft length of at least 60 mm to reach the deep-set screws.
      Ask FixBot
    4. SAFFUN Wireless N64 Controller Battery Replacement: step 4, image 1 of 3 SAFFUN Wireless N64 Controller Battery Replacement: step 4, image 2 of 3 SAFFUN Wireless N64 Controller Battery Replacement: step 4, image 3 of 3
      • Slide an opening pick along the edge of the rear cover to release the clips.
      • Gently remove the back plate from the controller.
      Ask FixBot
    1. SAFFUN Wireless N64 Controller Battery Replacement, Battery: step 5, image 1 of 2 SAFFUN Wireless N64 Controller Battery Replacement, Battery: step 5, image 2 of 2
      • Carefully remove the battery from the holder.
      • Don't rip out the wires. The battery is still attached to the controller.
      Ask FixBot
    2. SAFFUN Wireless N64 Controller Battery Replacement: step 6, image 1 of 2 SAFFUN Wireless N64 Controller Battery Replacement: step 6, image 2 of 2
      • Remove the rumble motor and its holder.
      Ask FixBot
    3. SAFFUN Wireless N64 Controller Battery Replacement: step 7, image 1 of 1
      • Locate the power supply unit (PSU) on the motherboard shown by the red square.
      Ask FixBot
    4. SAFFUN Wireless N64 Controller Battery Replacement: step 8, image 1 of 3 SAFFUN Wireless N64 Controller Battery Replacement: step 8, image 2 of 3 SAFFUN Wireless N64 Controller Battery Replacement: step 8, image 3 of 3
      • Squeeze the side clips on the battery connector and pull the battery cable straight out of its socket on the board.
      • Do not pull on the wires, as this can damage the connector.
      Ask FixBot
Jacob Overcash
541 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 40
All Time: 277
