Ryobi RY42102 Leaf Blower Fan Replacement
  1. Ryobi RY42102 Leaf Blower Fan Replacement, Fan in blower: step 1, image 1 of 3 Ryobi RY42102 Leaf Blower Fan Replacement, Fan in blower: step 1, image 2 of 3 Ryobi RY42102 Leaf Blower Fan Replacement, Fan in blower: step 1, image 3 of 3
    • Lay the blower on its side so that most of the screw heads are facing up. Identify all 9 screw locations.
    • One screw is located under the sticker with the number 8 on it.
    • Another screw is located on the opposite side.
  2. Ryobi RY42102 Leaf Blower Fan Replacement: step 2, image 1 of 1
    • Using a T15 torx drive(star-head), carefully remove each of the 9 screws and set aside in a secure location. All 9 screws are 10 mm long.
  3. Ryobi RY42102 Leaf Blower Fan Replacement: step 3, image 1 of 2 Ryobi RY42102 Leaf Blower Fan Replacement: step 3, image 2 of 2
    • After all 9 screws have been removed, seperate the handle housing the on/off switch.
  4. Ryobi RY42102 Leaf Blower Fan Replacement: step 4, image 1 of 1
    • Once the handle has been separated, the blower shaft with detach from the motor housing. Slide the blower shaft out of the motor housing and set aside.
  5. Ryobi RY42102 Leaf Blower Fan Replacement: step 5, image 1 of 1
    • Once the blower shaft is detached, the fan will be visible. Use a ratchet with a 1/2" socket to remove the 1/2" nut securing the fan to the motor. This nut is reverse thread so turning it clockwise will loosen it. The fan will also need to be secured so that it does not spin as the nut is being loosened.
  6. Ryobi RY42102 Leaf Blower Fan Replacement: step 6, image 1 of 3 Ryobi RY42102 Leaf Blower Fan Replacement: step 6, image 2 of 3 Ryobi RY42102 Leaf Blower Fan Replacement: step 6, image 3 of 3
    • Remove new fan from package and install as shown. Screw the nut back on to secure the fan. Remember the nut is reverse thread, so turning it counter clockwise will tighten it. The fan will also need to be secured while the nut is being tightened.
  7. Ryobi RY42102 Leaf Blower Fan Replacement: step 7, image 1 of 3 Ryobi RY42102 Leaf Blower Fan Replacement: step 7, image 2 of 3 Ryobi RY42102 Leaf Blower Fan Replacement: step 7, image 3 of 3
    • Slide blower shaft back into motor housing, close handle back around blower shaft and motor housing, and screw all 9 screws back into their location.
Past 24 Hours: 6
Past 7 Days: 22
Past 30 Days: 123
All Time: 13,274
