Up to 20% off select tools
Rug Doctor Handle Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
0
Past 30 Days:
7
All Time:
229
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prerequisite guide only! Removes the handle from the body of the Rug Doctor.
    1. Rug Doctor Handle Replacement, Handle: step 1, image 1 of 1
      • Before you begin disassembly, make sure that the Rug Doctor is not plugged in and that all reservoirs are empty of liquids.
      • Unclip the clear hose from the back of the Rug Doctor.
      Ask FixBot
    2. Rug Doctor Handle Replacement: step 2, image 1 of 2 Rug Doctor Handle Replacement: step 2, image 2 of 2
      • Use a 7/16" (11 mm OK) wrench to hold the handle axle while you use a 7/16" socket to remove the cap nut securing the axle end.
      Ask FixBot
    3. Rug Doctor Handle Replacement: step 3, image 1 of 2 Rug Doctor Handle Replacement: step 3, image 2 of 2
      • Support the handle with one hand. It will be loose after this step.
      • Use fingers or pliers to pull out the handle axle.
      • If the axle feels hard to pull out, squeeze the handle release lever to release pressure on the axle.
      Ask FixBot
    4. Rug Doctor Handle Replacement: step 4, image 1 of 1
      • Detach the handle from the Rug Doctor and set it down.
      • If you need more cable slack, you can set the Rug Doctor on its side.
      Ask FixBot
Arthur Shi
354,290 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 229
