Roku 3 Motherboard Replacement
  1. Roku 3 Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Place the Roku 3 on the table face down and orient it so you can correctly read the writing.
  2. Roku 3 Motherboard Replacement: step 2, image 1 of 3 Roku 3 Motherboard Replacement: step 2, image 2 of 3 Roku 3 Motherboard Replacement: step 2, image 3 of 3
    • Pull back the rubber protection in the top right corner to locate the screw.
    • Repeat with the bottom right corner and bottom left corner.
  3. Roku 3 Motherboard Replacement: step 3, image 1 of 1
    • Remove the 9 mm screws from the three corners with a Hex 1.3 Screwdriver.
  4. Roku 3 Motherboard Replacement: step 4, image 1 of 2 Roku 3 Motherboard Replacement: step 4, image 2 of 2
    • Open the device by gently lifting the bottom half away from the top half of the device.
  5. Roku 3 Motherboard Replacement: step 5, image 1 of 1
    • Use your fingers to carefully lift the motherboard from the top half of the device.
  6. Roku 3 Motherboard Replacement: step 6, image 1 of 2 Roku 3 Motherboard Replacement: step 6, image 2 of 2
    • Pull away the IO shield from the motherboard using your hands.
Samantha Miller
287 Reputation
1 Guide authored
Cal Poly, Team 15-2, Livingston Fall 2016 Member of Cal Poly, Team 15-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G2
3 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 49
All Time: 5,544
