RIDGID X4 18V Lithium-Ion Impact Driver Fuse Cartridge Replacement
  1. RIDGID X4 18V Lithium-Ion Impact Driver Fuse Cartridge Replacement, Disassembling Ridgid R86034 Housing: step 1, image 1 of 1
    • Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
    • Use some force; the rubber cover is securely attached to the housing.
    • Rotate the casing until it fits onto the housing with no gaps between it and the clear cover.
    • Orientation is important when putting the rubber cover on the casing.
  2. RIDGID X4 18V Lithium-Ion Impact Driver Fuse Cartridge Replacement: step 2, image 1 of 2 RIDGID X4 18V Lithium-Ion Impact Driver Fuse Cartridge Replacement: step 2, image 2 of 2
    • Remove the plastic cover with your hands.
    • There is no need to force off the plastic cover. The plastic cover should be much easier to remove than the rubber cover.
  3. RIDGID X4 18V Lithium-Ion Impact Driver Fuse Cartridge Replacement: step 3, image 1 of 3 RIDGID X4 18V Lithium-Ion Impact Driver Fuse Cartridge Replacement: step 3, image 2 of 3 RIDGID X4 18V Lithium-Ion Impact Driver Fuse Cartridge Replacement: step 3, image 3 of 3
    • Unscrew the four 16 mm long screws from the back panel with a T10 Torx Screwdriver.
    • Use a firm grip to peel off the back panel. It is sealed tight and requires a good amount of force to remove.
  4. RIDGID X4 18V Lithium-Ion Impact Driver Fuse Cartridge Replacement: step 4, image 1 of 2 RIDGID X4 18V Lithium-Ion Impact Driver Fuse Cartridge Replacement: step 4, image 2 of 2
    • Unscrew the eight 15 mm T10 Torx screws from the housing
    • The screw hole located nearest the battery port is deep and small. Most screwdrivers with replaceable bits will not fit into the hole. Instead, use a conventional screwdriver that fits.
  5. RIDGID X4 18V Lithium-Ion Impact Driver Fuse Cartridge Replacement: step 5, image 1 of 1
    • Place the driver flat on a table before completely separating the two halves of the housing so components of the drill don't fall out during opening.
    • Pry apart the two halves of the housing at the back side of the driver using the metal spudger.
    • The housing is easier to remove if you pry from multiple sides.
  6. RIDGID X4 18V Lithium-Ion Impact Driver Fuse Cartridge Replacement: step 6, image 1 of 2 RIDGID X4 18V Lithium-Ion Impact Driver Fuse Cartridge Replacement: step 6, image 2 of 2
    • Do not remove the direction switch.
    • Pull out all electrical components from housing by hand.
    • Lift out the motor.
    • Follow the wires.
    • The components should come out of their respective slots with ease and require little force to lift out.
    • The circuit board located nearest the battery pack and the LED light will be hard to pull out.
    • Remember to precisely place all components in their correct slots with their correct orientations when reassembling.
  7. RIDGID X4 18V Lithium-Ion Impact Driver Fuse Cartridge Replacement, Fuse Cartridge: step 7, image 1 of 1
    • Identify the translucent orange fuse cartridge connected by a thick red wire and a thick white wire.
  8. RIDGID X4 18V Lithium-Ion Impact Driver Fuse Cartridge Replacement: step 8, image 1 of 3 RIDGID X4 18V Lithium-Ion Impact Driver Fuse Cartridge Replacement: step 8, image 2 of 3 RIDGID X4 18V Lithium-Ion Impact Driver Fuse Cartridge Replacement: step 8, image 3 of 3
    • Firmly grasp the orange fuse cartridge and pull it out of its socket.
    • The fuse does not come out easy, don't be afraid to pull hard to get it to come out.
  9. RIDGID X4 18V Lithium-Ion Impact Driver Fuse Cartridge Replacement: step 9, image 1 of 3 RIDGID X4 18V Lithium-Ion Impact Driver Fuse Cartridge Replacement: step 9, image 2 of 3 RIDGID X4 18V Lithium-Ion Impact Driver Fuse Cartridge Replacement: step 9, image 3 of 3
    • Insert the new fuse cartridge.
Tommy Lovelace
207 Reputation
2 Guides authored
Cal Poly, Team 15-5, Amido Spring 2015 Member of Cal Poly, Team 15-5, Amido Spring 2015
CPSU-AMIDO-S15S15G5
4 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 1,171
