Introduction
If you blow a fuse in the impact driver you only have to open up the device and replace the broken fuse with a new one.
Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
Unscrew the four 16 mm long screws from the back panel with a T10 Torx Screwdriver.
Use a firm grip to peel off the back panel. It is sealed tight and requires a good amount of force to remove.
Pry apart the two halves of the housing at the back side of the driver using the metal spudger.
Pull out all electrical components from housing by hand.
Lift out the motor.
Follow the wires.
