Retroid Pocket Flip Battery Replacement
    1. Retroid Pocket Flip Battery Replacement, Back Plate Assembly: step 1, image 1 of 2 Retroid Pocket Flip Battery Replacement, Back Plate Assembly: step 1, image 2 of 2
      • Remove the four 5.9 mm screws from the backplate of the device with a 1.3mm hex screwdriver.
      • Use a plastic opening pick to carefully separate the back cover from the device.
      Ask FixBot
    2. Retroid Pocket Flip Battery Replacement: step 2, image 1 of 2 Retroid Pocket Flip Battery Replacement: step 2, image 2 of 2
      • Use a plastic spudger to carefully lift and disconnect the battery connector.
      • Use tweezers to disconnect the connector from its socket.
      Ask FixBot
    1. Retroid Pocket Flip Battery Replacement, Battery: step 3, image 1 of 1
      • Use an opening tool to lift the battery from the back cover.
      • Continue lifting the battery slowly until it is fully separated from the back cover.
      • Do not bend, puncture, or damage the battery during removal.
      Ask FixBot
Melissa Boussa
331 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 43
Past 30 Days: 207
All Time: 806
