Resetting Windows 10
  1. Resetting Windows 10, Open settings: step 1, image 1 of 2 Resetting Windows 10, Open settings: step 1, image 2 of 2
    • Press Windows + I to open your settings window.
    • Then click "Update & security"
  2. Resetting Windows 10, Recovery: step 2, image 1 of 1
    • From the settings window click "Recovery"
  3. Resetting Windows 10, Reset: step 3, image 1 of 1
    • From the recovery menu click "Get started" under "Reset this PC"
  4. Resetting Windows 10, Keep or Remove your files: step 4, image 1 of 1
    • You are then asked to choose one of two options. Pick one that would best suit your needs.
    • Keep my Files: This will keep any files you have stored in the windows Documents, Pictures and Videos folders etc. This will result in a fresh install of windows but keep all your files.
    • Remove everything: This will completely refresh the windows OS, free from any files or apps that where on before, any files stored on other drives or partitions will remain. Make sure you back up any data you want to keep before choosing this option.
  5. Resetting Windows 10, A few more clicks: step 5, image 1 of 3 Resetting Windows 10, A few more clicks: step 5, image 2 of 3 Resetting Windows 10, A few more clicks: step 5, image 3 of 3
    • After a short wait, windows will let you know what apps will be uninstalled. Click "Next"
    • After reading a quick overview of what is about to happen. Click "Reset"
  6. Resetting Windows 10, Lots of loading: step 6, image 1 of 3 Resetting Windows 10, Lots of loading: step 6, image 2 of 3 Resetting Windows 10, Lots of loading: step 6, image 3 of 3
    • The rest is automatic and will take some time. Make yourself a cup of tea and relax.
  7. Resetting Windows 10, Finishing touches: step 7, image 1 of 3 Resetting Windows 10, Finishing touches: step 7, image 2 of 3 Resetting Windows 10, Finishing touches: step 7, image 3 of 3
    • Once the reset is finished just log in as normal.
    • Windows will make a few final changes, and your done!
    • On your desktop will be a html file that will contain all the apps that were removed.
Conor Bailey
7,971 Reputation
2 Guides authored
Tech Haus Member of Tech Haus
Business
1 Member
12 Guides authored
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 26
All Time: 3,597
