Replace the Bottom Cover
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Replace the Bottom Cover, Shut down the laptop: step 1, image 1 of 3 Replace the Bottom Cover, Shut down the laptop: step 1, image 2 of 3 Replace the Bottom Cover, Shut down the laptop: step 1, image 3 of 3
      • If you've installed an operating system, follow the appropriate steps to safely shut down the laptop.
      • If you've not yet installed an operating system, or the laptop is not responsive, you can shut it down with these steps:
      • Turn on the OLED screen by pressing the Hyper key (diagonal arrow) and Enter at the same time.
      • Use the arrow keys to select Power Off on the OLED screen.
      • Press Enter to shut down the laptop.
      • Disconnect all cables from the laptop.
      Ask FixBot
    2. Replace the Bottom Cover, Turn off the standby power: step 2, image 1 of 2 Replace the Bottom Cover, Turn off the standby power: step 2, image 2 of 2
      • Use a small tool, like a SIM eject tool or a bent paperclip, to turn off the standby power switch by sliding the switch away from the headset jack.
      • The standby power switch is located in a small recess on the same side as the headset jack.
      Ask FixBot
    1. Replace the Bottom Cover, Remove the bottom cover screws: step 3, image 1 of 2 Replace the Bottom Cover, Remove the bottom cover screws: step 3, image 2 of 2
      • Place the laptop on your work surface so the bottom cover, with the regulatory info box, is facing up.
      • Use a Phillips screwdriver to remove the six 4.8 mm‑long screws securing the bottom cover.
      Ask FixBot
    2. Replace the Bottom Cover, Remove the bottom cover: step 4, image 1 of 3 Replace the Bottom Cover, Remove the bottom cover: step 4, image 2 of 3 Replace the Bottom Cover, Remove the bottom cover: step 4, image 3 of 3
      • The bottom cover is made of printed circuit board (PCB) material. Press gently but firmly near an edge when applying the suction handle to avoid breaking the cover.
      • Apply a suction handle to the bottom cover.
      • Use the suction handle to lift the bottom cover off of the laptop.
      • Alternatively, you can use a thin prying tool to lift the cover, or tilt the laptop until the cover falls out.
      • During reassembly, place the bottom cover on the laptop so the info box is opposite the hinges.
      Ask FixBot
    1. Replace the Bottom Cover, Disconnect the batteries: step 5, image 1 of 3 Replace the Bottom Cover, Disconnect the batteries: step 5, image 2 of 3 Replace the Bottom Cover, Disconnect the batteries: step 5, image 3 of 3
      • Be careful not to damage the lithium-polymer batteries when working around them with metal tools. If the batteries are damaged or deformed in any way, take appropriate precautions.
      • Use a pair of tweezers or your fingers to disconnect the batteries' sliding connectors from the charger board.
      Ask FixBot
    2. Replace the Bottom Cover, Remove the batteries: step 6, image 1 of 3 Replace the Bottom Cover, Remove the batteries: step 6, image 2 of 3 Replace the Bottom Cover, Remove the batteries: step 6, image 3 of 3
      • Lift the batteries out of the frame.
      • During reassembly, install the batteries so the foam stickers face up, the sides of the batteries with wires are towards the hinges, and the wires run towards the middle of the laptop.
      Ask FixBot
    1. Replace the Bottom Cover, Secure the bottom cover: step 7, image 1 of 3 Replace the Bottom Cover, Secure the bottom cover: step 7, image 2 of 3 Replace the Bottom Cover, Secure the bottom cover: step 7, image 3 of 3
      • Place the bottom cover on the laptop.
      • Use a Phillips screwdriver to secure the bottom cover with the six 4.8 mm‑long screws.
      Ask FixBot
Spencer Pennington
27,536 Reputation
125 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
61,630 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 15
All Time: 172
