This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Repairing the grinder
    1. Repairing the grinder, Metal or plastic trim frame?: step 1, image 1 of 2 Repairing the grinder, Metal or plastic trim frame?: step 1, image 2 of 2
      • First, check which model you have: is the trim frame made of chrome-plated metal (image 1) or metallized plastic (image 2)? In the first case, use this guide; in the second case, use this guide. Then return here.
      Ask FixBot
    2. Repairing the grinder, Grinder information: step 2, image 1 of 1
      • The grinder is easily accessible from the top. It sits loosely, but is connected with two cables and one cable to the sensor.
      • Do not change any settings.
      Ask FixBot
    3. Repairing the grinder, Disconnecting the connectors: step 3, image 1 of 2 Repairing the grinder, Disconnecting the connectors: step 3, image 2 of 2
      • Carefully lift the grinder and pull off the two spade connectors from the motor. You must press in a small locking tab on each connector to do this.
      • Be sure to note which cable is connected where, so that the motor does not run in reverse later.
      • Once you have lifted the grinder, you will also see the cable for the sensor on the underside. Trace the cable to the main board. Very carefully disconnect the connector.
      Ask FixBot
    4. Repairing the grinder, Lift out the grinder: step 4, image 1 of 1
      • Lift the grinder straight up and out. Feed the cables through the opening in the housing.
      • The seal on the coffee grounds chute is only inserted. Be careful not to lose it.
      • The damping spring is only inserted. Be careful not to lose it.
      • When reassembling, make sure that the holes in the rubber mount around the motor are properly seated on the corresponding pins.
      Ask FixBot
    1. Repairing the grinder, Before assembly: step 5, image 1 of 1
      • Take a photo of the mark on the large gear wheel; it should be in the same position when you reassemble it.
      • Although the motor is powered by 230 V, diodes ensure that only positive half-waves are supplied, so that the motor only rotates in one direction. Make a note of how the connection cables are plugged in. Test later to see if it is rotating in the correct direction.
      • You can test the motor with approximately 25 V DC. It should turn easily and draw approximately 120 mA. If this is not the case, check the carbon brushes on the side. Only then should you consider replacing it.
      • Insert translation here
      • Any brackets—in this case, the black rubber sleeve—must be transferred to the new part.
      • The speed sensor can only be removed from the inside. To do this, you must disconnect its plug from the main circuit board and expose the cables.
      Ask FixBot
    2. Repairing the grinder, Remove the motor: step 6, image 1 of 2 Repairing the grinder, Remove the motor: step 6, image 2 of 2
      • There are four Torx T10 screws on the underside of the grinding mechanism. Remove those.
      • The screw marked in yellow must not be removed when replacing the motor.
      • The white plastic sleeve around the screw marked in yellow must be transferred to the replacement part.
      • Lift off the motor.
      Ask FixBot
    3. Repairing the grinder, Transferring the sensor: step 7, image 1 of 3 Repairing the grinder, Transferring the sensor: step 7, image 2 of 3 Repairing the grinder, Transferring the sensor: step 7, image 3 of 3
      • The machine's electronic use the sensor to measure the number of revolutions. The sensor must be transferred to the new motor.
      • The sensor is secured on the inside with a locking tab. It can therefore only be removed from the inside.
      • Press the locking tab firmly down with a flat screwdriver.
      • Slide the sensor out, using the flat screwdriver to help if needed.
      • Transfer the sensor to the new part.
      Ask FixBot
    4. Repairing the grinder, Completion: step 8, image 1 of 1
      • Grease the worm gear on the new motor a little; the old grease may be sufficient, but new grease is better.
      • Check that the plastic bushing is seated properly in the center opening. Screw the motor tight.
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
VauWeh
342,364 Reputation
315 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 88
All Time: 611
