Repairing a Broken Coffee Mug Handle
  1. Repairing a Broken Coffee Mug Handle, Mug: step 1, image 1 of 1
    • Wash your mug clean and rinse the broken edges. Handle carefully to prevent further damage.
    • Make sure you don't cut yourself on any sharp edges.
  2. Repairing a Broken Coffee Mug Handle: step 2, image 1 of 3 Repairing a Broken Coffee Mug Handle: step 2, image 2 of 3 Repairing a Broken Coffee Mug Handle: step 2, image 3 of 3
    • Collect the pieces of the handle and place them on a few paper towels.
    • Piece them back together and make sure all of the parts are there.
  3. Repairing a Broken Coffee Mug Handle: step 3, image 1 of 2 Repairing a Broken Coffee Mug Handle: step 3, image 2 of 2
    • Take two of the broken pieces that fit together and glue them.
    • Cover the piece in a thin layer of glue (about one drop) and try to avoid getting glue on your hands, keep paper towels close by incase you do.
  4. Repairing a Broken Coffee Mug Handle: step 4, image 1 of 3 Repairing a Broken Coffee Mug Handle: step 4, image 2 of 3 Repairing a Broken Coffee Mug Handle: step 4, image 3 of 3
    • Continue glueing other pieces of the handle in place until all pieces are together.
    • Once the handle is glued together, wait for the glue to dry before moving on. It will take about 30 minutes to dry.
    • Be very delicate with the piece while it is drying. Before the glue sets the handle will be very fragile.
  5. Repairing a Broken Coffee Mug Handle: step 5, image 1 of 2 Repairing a Broken Coffee Mug Handle: step 5, image 2 of 2
    • After the handle has dried, test that the glued pieces are sturdy.
    • Do not purposely break it apart, but make sure that the pieces are secure.
    • If the handle happens to break anywhere, repeat step 4.
  6. Repairing a Broken Coffee Mug Handle: step 6, image 1 of 3 Repairing a Broken Coffee Mug Handle: step 6, image 2 of 3 Repairing a Broken Coffee Mug Handle: step 6, image 3 of 3
    • Once the handle is dried and secure. Begin placing glue on the cup where the handle should attach.
    • After gluing both places, gently press handle ends into place.
    • The handle should fit in almost perfectly when alined.
  7. Repairing a Broken Coffee Mug Handle: step 7, image 1 of 3 Repairing a Broken Coffee Mug Handle: step 7, image 2 of 3 Repairing a Broken Coffee Mug Handle: step 7, image 3 of 3
    • Now let the glue dry, and your mug is usable again.
    • Remember it will take about 30 minutes to dry.
    • I would not advise washing this mug in the dishwasher anymore because this makes it more likely to break again.
Kathryn Webb
254 Reputation
1 Guide authored
Cal Poly, Team 28-2, Green Spring 2015 Member of Cal Poly, Team 28-2, Green Spring 2015
CPSU-GREEN-S15S28G2
4 Members
2 Guides authored
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 102
All Time: 37,162
