Repairing PS4 Bluetooth Antenna from Defect or System fell
  1. Repairing PS4  Bluetooth Antenna from Defect or System fell, Remove the Wi-Fi antenna: step 1, image 1 of 2 Repairing PS4  Bluetooth Antenna from Defect or System fell, Remove the Wi-Fi antenna: step 1, image 2 of 2
    • Use the tip of a spudger to disconnect the antenna cable from the motherboard.
  2. Repairing PS4  Bluetooth Antenna from Defect or System fell: step 2, image 1 of 3 Repairing PS4  Bluetooth Antenna from Defect or System fell: step 2, image 2 of 3 Repairing PS4  Bluetooth Antenna from Defect or System fell: step 2, image 3 of 3
    • Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides.
  3. Repairing PS4  Bluetooth Antenna from Defect or System fell: step 3, image 1 of 3 Repairing PS4  Bluetooth Antenna from Defect or System fell: step 3, image 2 of 3 Repairing PS4  Bluetooth Antenna from Defect or System fell: step 3, image 3 of 3
    • Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable.
  4. Repairing PS4  Bluetooth Antenna from Defect or System fell: step 4, image 1 of 2 Repairing PS4  Bluetooth Antenna from Defect or System fell: step 4, image 2 of 2
    • Remove the 9.7 mm Torx security screw securing the antenna.
  5. Repairing PS4  Bluetooth Antenna from Defect or System fell: step 5, image 1 of 2 Repairing PS4  Bluetooth Antenna from Defect or System fell: step 5, image 2 of 2
    • Remove the Wi-Fi antenna.
  6. Repairing PS4  Bluetooth Antenna from Defect or System fell, What is Wrong?: step 6, image 1 of 1
    • As you can see there are 2 solder points . the wire must run through the first point to the second point. But when the system fell it broke that connection and Antenna got bent. If at factory the solder points were not correct it will cause the same lag issue with controller and WiFi.
  7. Repairing PS4  Bluetooth Antenna from Defect or System fell, Solder it back: step 7, image 1 of 1
    • This is the easy part. Remove the antenna. Move the wire inbetween the two solder points so it is connecting to the second point. Once there take your soldering Iron and heat up the solder and drag it over the wire to make the connection.
    • Just remember to leave the gap here. Do not bend the antenna to make the points touch your self. The gap that runs through it is there by design and changing that has adverse effects on controller and WiFi . But its that easy. My PS4 now works fine with controller and WiFi . No need for further tear-down and extra parts. Put bottom on. GTGo
bdcallen69
1,159 Reputation
1 Guide authored
Past 24 Hours: 19
Past 7 Days: 173
Past 30 Days: 731
All Time: 190,251
