How to Bose On-Ear headphones
  1. How to Bose On-Ear headphones, How to Bose On-Ear headphones: step 1, image 1 of 3 How to Bose On-Ear headphones, How to Bose On-Ear headphones: step 1, image 2 of 3 How to Bose On-Ear headphones, How to Bose On-Ear headphones: step 1, image 3 of 3
    • Here is the Bose Tricore OE headset. Slightly worn, it does not produce any sound to the right side driver
    • Remove the ear pads by simply applying a bit of force between the ear pads and the housing. The ear pad will simply snap off
    • This shows the snaps that attach the ear pad to the case.
  2. How to Bose On-Ear headphones: step 2, image 1 of 3 How to Bose On-Ear headphones: step 2, image 2 of 3 How to Bose On-Ear headphones: step 2, image 3 of 3
    • With the ear pad removed, the Phillips screws that hold the drive to the case, are now visible.
    • Remove the two screws on top
    • There are two more under the padding on the bottom. Remove those as well.
  3. How to Bose On-Ear headphones: step 3, image 1 of 3 How to Bose On-Ear headphones: step 3, image 2 of 3 How to Bose On-Ear headphones: step 3, image 3 of 3
    • All four screws are the same length, 6mm. No need to separate them.
    • With the screws removed, the driver (speaker) can now simply removed by just folding it over.
    • There is a small PCB to which the driver (speaker) mounts. Check the solder connections of the driver (speaker) to the board, as well as the components on this board. It consist of a few caps, resistors, and a coil.
  4. How to Bose On-Ear headphones: step 4, image 1 of 3 How to Bose On-Ear headphones: step 4, image 2 of 3 How to Bose On-Ear headphones: step 4, image 3 of 3
    • Since both driver (speaker) wiring will be checked, remove the left ear pad as well.
    • Same screw configuration. Two screws on top,
    • two screws under the bottom pad,
  5. How to Bose On-Ear headphones: step 5, image 1 of 3 How to Bose On-Ear headphones: step 5, image 2 of 3 How to Bose On-Ear headphones: step 5, image 3 of 3
    • The Phillips screws are identical and do not need to be separated
    • Remove the driver from the case by simply flipping it to the side.
    • Same PCB on both sides. Check the solder connections from the driver (speaker) to the PCB.
  6. How to Bose On-Ear headphones: step 6, image 1 of 3 How to Bose On-Ear headphones: step 6, image 2 of 3 How to Bose On-Ear headphones: step 6, image 3 of 3
    • Here is the PCB of the right side driver (speaker)
    • Simple setup to test the driver (speaker) Two leads with alligator clips, connect those to an 3.5mm audio jack extension.
    • Use those leads and touch the connector of the driver (speaker) on the PCB. There will be sound if the driver (speaker) is working.
  7. How to Bose On-Ear headphones: step 7, image 1 of 3 How to Bose On-Ear headphones: step 7, image 2 of 3 How to Bose On-Ear headphones: step 7, image 3 of 3
    • Time to disassemble the left side. Remove the ear pad
    • then the two on the bottom.
  8. How to Bose On-Ear headphones: step 8, image 1 of 3 How to Bose On-Ear headphones: step 8, image 2 of 3 How to Bose On-Ear headphones: step 8, image 3 of 3
    • Remove the driver (speaker) from the case
    • Make note off how the audio jack cable is fastened.
    • Remove the audio jack cable from the case. It is simply a rubber plug that is pressed into the case.
  9. How to Bose On-Ear headphones: step 9, image 1 of 3 How to Bose On-Ear headphones: step 9, image 2 of 3 How to Bose On-Ear headphones: step 9, image 3 of 3
    • Check the driver (speaker) the same way as on the left side.
    • On this headset, both drivers worked while being tested, but not when the audio was connected to the audio jack. The jack needed to be replaced.
    • Desolder the audio jack cable by using a soldering wick. Apply flux to the wick prior to unsoldering.
    • Remove the old audio jack cable.
  10. How to Bose On-Ear headphones: step 10, image 1 of 3 How to Bose On-Ear headphones: step 10, image 2 of 3 How to Bose On-Ear headphones: step 10, image 3 of 3
    • Here is the rubber boot that holds the audio jack cable in place.
    • Insert the replacement cable as shown through the boot. Solder the new cable to the PCB.
    • Reassemble the headphones after double checking the solder job. This one also received new ear pads (readily available at online auction sites) and works perfectly.
oldturkey03
783,931 Reputation
119 Guides authored
Global Fixers Member of Global Fixers
Community
33 Members
555 Guides authored
Past 24 Hours: 8
Past 7 Days: 28
Past 30 Days: 113
All Time: 93,303
