Braun Cruzer 6 Type 5417 Battery Replacement
  1. Braun Cruzer 6 Type 5417 Battery Replacement, Braun Cruzer 6 Type 5417 Battery Replacement: step 1, image 1 of 3 Braun Cruzer 6 Type 5417 Battery Replacement, Braun Cruzer 6 Type 5417 Battery Replacement: step 1, image 2 of 3 Braun Cruzer 6 Type 5417 Battery Replacement, Braun Cruzer 6 Type 5417 Battery Replacement: step 1, image 3 of 3
    • Remove the trimmer head.
    • Remove the two Torx T5 screws attaching the cover to the hand-piece.
    • Remove the cover.
    • Take this opportunity to remove built up hair and residue. Hair can prevent the batteries from making contact leading to power failure.
  2. Braun Cruzer 6 Type 5417 Battery Replacement: step 2, image 1 of 3 Braun Cruzer 6 Type 5417 Battery Replacement: step 2, image 2 of 3 Braun Cruzer 6 Type 5417 Battery Replacement: step 2, image 3 of 3
    • Remove the back cover.
    • Using a flat head screw driver, remove the single screw holding the power board in place.
    • Use compressed air to clean the motor. Take this opportunity to lubricate the trimmer with an anti-rust spray or WD-40.
    • Remove the two AAA batteries by soldering them with soldering iron and des soldering pump.
    • Bend the terminals of the new batteries and solder them back in the right direction
    • If the batteries are already slightly charged, you can briefly press the power button to check if the motor is working
    • Insert the board again, with the side towards the motor first
  3. Braun Cruzer 6 Type 5417 Battery Replacement: step 3, image 1 of 3 Braun Cruzer 6 Type 5417 Battery Replacement: step 3, image 2 of 3 Braun Cruzer 6 Type 5417 Battery Replacement: step 3, image 3 of 3
    • OPTIONALAdditional improvements to the trimmer's performance by removing the upper-cover and removing any built up hair. You can also lubricate the blades.
23 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Zweikeks
586 Reputation
2 Guides authored
7 Comments
Your guide saved me from purchasing a new device.
After replacing the batteries it works again like a charm!
King Arthur - Reply
Thanks this was helpful. The Braun Series 3 Hair Clipper HC3050 has a VERY similar design. Some additional notes: After removing the screws, it takes a bit of force to get the back separated from the front. I had to gently pry it apart with a screw driver. The very inside is slightly different, but same concept.
Jaden Fox - Reply
Die Anleitung war sehr hilfreich.
Der Austausch der Batterien ging ziemlich gut.
Wilhelm Gregorius - Reply
I think one pcc— 1.2 V 1800 mah AA battary
Ünsal Şeker - Reply
Thank you! Another appliance reborn :)
It really helps to work around consumerism with such shared knowledge!
Keep it up 👍
Pedro Faria - Reply
Past 24 Hours: 12
Past 7 Days: 103
Past 30 Days: 423
All Time: 27,695
