This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Introduction
Utilisez ce tutoriel pour remplacer un lecteur DVD en panne.
Utilisez une spatule (spudger) en métal pour retirer les caches de vis en plastique blanc, collés sous la coque inférieure, à l'avant de la Wii.
Ouvrez la trappe d'accès aux ports contrôleur jusqu'à ce qu'elle soit perpendiculaire à la plaque noire des ports.
Tirez la trappe vers le haut pour la détacher de la coque externe.
Enlevez la petite vis cruciforme fixant la trappe de la pile à la coque inférieure.
Tirez la trappe hors de la Wii.
Pour remonter l'appareil, suivez les instructions dans l'ordre inverse.
40 other people completed this guide.
Special thanks to these translators:
75%
These translators are helping us fix the world! Want to contribute?
Start translating ›
7 Comments
My problem was an object that had been lodged in the drive - in fact, I didn't need to replace the drive. I successfully followed thru step 19, and at that point, I was able to extract the foreign object through the gaps in the disc housing. Then I reversed the steps through to the start and everything is working again.
I used this to access the drive area where I successfully identified and removed a plastic toy 50p coin my 2 yr old had carefully inserted in it; The Wii works again now
I am v gratefuil for these excellent instructions
And a tip - use a computer/laptop to view; an iphone was a wee (Wii?) bit too small!
You can also download our free iPad app.
