Replacement of the battery on Dell XPS 13 9380
  1. Replacement of the battery on Dell XPS 13 9380, Remove the back panel: step 1, image 1 of 3 Replacement of the battery on Dell XPS 13 9380, Remove the back panel: step 1, image 2 of 3 Replacement of the battery on Dell XPS 13 9380, Remove the back panel: step 1, image 3 of 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Torx T5 driver to unscrew the eight screws securing the back panel.
    • Use a spudger to pry up and loosen the back panel.
    • Lift the back panel up slightly from the non-hinged edge.
    • Pull the back panel away from the hinged edge, wiggling it back and forth to loosen the clips.
    • When the back panel clips are free, remove the back panel.
  2. Replacement of the battery on Dell XPS 13 9380, Remove the battery: step 2, image 1 of 2 Replacement of the battery on Dell XPS 13 9380, Remove the battery: step 2, image 2 of 2
    • Disconnect the cable from the battery by pulling the connector towards the battery.
    • Pull parallel to the battery, not straight up.
    • Remove the four screws (M2 x 2) securing the battery.
    • Remove the screw (M1.6 x 4) securing the battery.
    • Remove the battery from its recess.
To reassemble your device, follow the instructions in reverse order.
15 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Schwarzer
4,844 Reputation
13 Guides authored
i.Fixit FR Team Member of i.Fixit FR Team
Community
3 Members
40 Guides authored
2 Comments
The backpanel is a bit tricky to remove, but it can be managed.
The "Essential Electronics Toolkit" is very useful! I recommend to order it with the battery.
Andreas Köcher - Reply
I am confused because according to dell.com the battery for the XPS 13 9380 is the G7GV0, not the G8VCF (DXGH8) which you are selling here:
https://www.dell.com/en-uk/shop/dell-4-c...
vs.
Mike - Reply
Past 24 Hours: 18
Past 7 Days: 79
Past 30 Days: 341
All Time: 15,791
