Removing DJI Phantom 2 Vision+ Case Top Shell
  1. Removing DJI Phantom 2 Vision+ Case Top Shell, Remove the battery: step 1, image 1 of 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Remove the battery: step 1, image 2 of 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Remove the battery: step 1, image 3 of 3
    • Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
    • The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
  2. Removing DJI Phantom 2 Vision+ Case Top Shell, Propellers: step 2, image 1 of 1
    • Determine if the propellor is clockwise or counter-clockwise rotating.
    • Each arm is labeled with a rotation icon that shows the direction of propellor rotation.
    • If this icon is missing or you can't read it, you can determine the direction of rotation by examining the propellor.
    • A clockwise rotating propellor pushes air down while rotating clockwise, and the opposite is true for a counter-clockwise rotating propellor, and the propellor blade slopes up in the direction of rotation.
  3. Removing DJI Phantom 2 Vision+ Case Top Shell, Removing clockwise rotating propellers: step 3, image 1 of 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Removing clockwise rotating propellers: step 3, image 2 of 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Removing clockwise rotating propellers: step 3, image 3 of 3
    • Loosen a clockwise rotating propeller by holding the motor with one hand and spinning the propellor clockwise.
    • Remove the propellor.
  4. Removing DJI Phantom 2 Vision+ Case Top Shell, Removing counter-clockwise rotating propellers: step 4, image 1 of 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Removing counter-clockwise rotating propellers: step 4, image 2 of 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Removing counter-clockwise rotating propellers: step 4, image 3 of 3
    • Loosen a counter-clockwise rotating propeller by holding the motor with one hand and spinning the propellor counter-clockwise.
  5. Removing DJI Phantom 2 Vision+ Case Top Shell, Case Top Shell: step 5, image 1 of 2 Removing DJI Phantom 2 Vision+ Case Top Shell, Case Top Shell: step 5, image 2 of 2
    • Remove the following screws from the underside of the Phantom:
    • Twelve 2.0 mm hex bolts
    • Four Phillips #00 screws
  6. Removing DJI Phantom 2 Vision+ Case Top Shell: step 6, image 1 of 2 Removing DJI Phantom 2 Vision+ Case Top Shell: step 6, image 2 of 2
    • Gently lift up the top shell case.
    • Do not attempt to fully remove the top shell. The GPS cable is still attached to the mainboard, avoid lifting the case too high or you may damage this connection.
  7. Removing DJI Phantom 2 Vision+ Case Top Shell, Unplug GPS connector and remove case: step 7, image 1 of 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Unplug GPS connector and remove case: step 7, image 2 of 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Unplug GPS connector and remove case: step 7, image 3 of 3
    • The GPS cable molex connector is located on the backside of the mainboard, near the battery opening.
    • Pull the GPS connector straight up out of its socket.
    • Lift the top shell case up and remove it from the body of the Phantom.
11 other people completed this guide.
David Hoyt
4,023 Reputation
43 Guides authored
Cal Poly, Team 25-89, Amido Spring 2010 Member of Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Members
63 Guides authored
2 Comments
This guild will also largely work for the Phantom 3 (Adv./Pro) with the difference being that the phillips-head screws are T7s in the P3, and the 2mm Allen/Hex bolts are T8s.
anonymous 4102 - Reply
Does anyone know what the size and thread pitch for the “2.0 mm hex bolts” are? I lost the screws and need a replacement.
Matt Hirsch - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 15
All Time: 11,079
