Meta Quest 2 Head Strap Replacement
  1. Meta Quest 2 Head Strap Replacement, Remove the facial interface: step 1, image 1 of 2 Meta Quest 2 Head Strap Replacement, Remove the facial interface: step 1, image 2 of 2
    • Grasp and pull on the nose section of the facial interface to unclip it from the headset.
  2. Meta Quest 2 Head Strap Replacement: step 2, image 1 of 2 Meta Quest 2 Head Strap Replacement: step 2, image 2 of 2
    • Grasp and pull on the top section of the facial interface to unclip it from the headset.
  3. Meta Quest 2 Head Strap Replacement: step 3, image 1 of 1
    • Remove the facial interface.
    • During reassembly, align the facial interface to the headset and use your fingers to press along the perimeter to clip it back in.
  4. Meta Quest 2 Head Strap Replacement, Unclip the side straps: step 4, image 1 of 3 Meta Quest 2 Head Strap Replacement, Unclip the side straps: step 4, image 2 of 3 Meta Quest 2 Head Strap Replacement, Unclip the side straps: step 4, image 3 of 3
    • Use your fingers to grasp the right strap near the headset.
    • Peel the right strap away from the headset arm to unclip it.
  5. Meta Quest 2 Head Strap Replacement: step 5, image 1 of 2 Meta Quest 2 Head Strap Replacement: step 5, image 2 of 2
    • Repeat the procedure to peel the left strap away from the arm to unclip it.
  6. Meta Quest 2 Head Strap Replacement, Remove the top strap: step 6, image 1 of 2 Meta Quest 2 Head Strap Replacement, Remove the top strap: step 6, image 2 of 2
    • Separate the hook and loop strip on the top strap.
  7. Meta Quest 2 Head Strap Replacement, Remove the head strap: step 7, image 1 of 2 Meta Quest 2 Head Strap Replacement, Remove the head strap: step 7, image 2 of 2
    • Unthread the top strap from its bracket.
    • Remove the head strap.
15 other people completed this guide.
Arthur Shi
253,469 Reputation
526 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,198 Guides authored
0 Comments
Past 24 Hours: 41
Past 7 Days: 286
Past 30 Days: 1,215
All Time: 26,775
