Remove PowerMac G4 M5183 Main Fan
  1. Remove PowerMac G4 M5183 Main Fan, Opening PowerMac G4 M5183 Case: step 1, image 1 of 2 Remove PowerMac G4 M5183 Main Fan, Opening PowerMac G4 M5183 Case: step 1, image 2 of 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Remove PowerMac G4 M5183 Main Fan, Main Fan: step 2, image 1 of 2 Remove PowerMac G4 M5183 Main Fan, Main Fan: step 2, image 2 of 2
    • Remove the screw from each of the two niches on lower part of fan using the Phillips #1 screwdriver.
    • The fan housing will still be connected to the computer by a power cable which will be removed in the next step.
  3. Remove PowerMac G4 M5183 Main Fan: step 3, image 1 of 1
    • Remove the power cable from the fan and detach bracing.
Justin Petrilli
3,114 Reputation
11 Guides authored
Cal Poly, Team 13-24, Maness Winter 2010 Member of Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Members
25 Guides authored
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 15
All Time: 5,448
