Redragon Sniper Pro M801-RGB LED Diffuser Replacement
    1. Redragon Sniper Pro M801-RGB LED Diffuser Replacement, LED Diffuser: step 1, image 1 of 1
      • Remove the four skates on the bottom of the mouse.
      • Take care not to warp or tear the skates if you intend to reuse them.
      Ask FixBot
    2. Redragon Sniper Pro M801-RGB LED Diffuser Replacement: step 2, image 1 of 1
      • Use a Phillips screwdriver to remove the 5 screws (one 2.5 mm screw and four 9.0 mm screws) on the bottom of the mouse.
      Ask FixBot
    3. Redragon Sniper Pro M801-RGB LED Diffuser Replacement: step 3, image 1 of 1
      • Open up the mouse without disconnecting wires.
      Ask FixBot
    4. Redragon Sniper Pro M801-RGB LED Diffuser Replacement: step 4, image 1 of 1
      • Take out the LED diffuser.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 63
All Time: 166
