Redmi Note 4 Global Display Replacement
  1. Redmi Note 4 Global Display Replacement, Display: step 1, image 1 of 2 Redmi Note 4 Global Display Replacement, Display: step 1, image 2 of 2
    • Use a pin to remove the SIM & SD card
  2. Redmi Note 4 Global Display Replacement: step 2, image 1 of 3 Redmi Note 4 Global Display Replacement: step 2, image 2 of 3 Redmi Note 4 Global Display Replacement: step 2, image 3 of 3
    • With the help of a silicone spatula or similar opening tool, press gently into the separation between housing and screen
    • Gently pry the frame away from the screen .
  3. Redmi Note 4 Global Display Replacement: step 3, image 1 of 1
    • Disconnect the rest of all the connectors. (Image shows fingerprint scanner connector already removed)
  4. Redmi Note 4 Global Display Replacement: step 4, image 1 of 3 Redmi Note 4 Global Display Replacement: step 4, image 2 of 3 Redmi Note 4 Global Display Replacement: step 4, image 3 of 3
    • First disconnect the connector for the fingerprint scanner
    • Then carefully pry the scanner (it is adhered to the board )
    • Preheating the scanner area with a hair dryer can help
  5. Redmi Note 4 Global Display Replacement: step 5, image 1 of 1
    • Remove all Phillips screws screws eg with a #00 Phillips driver
  6. Redmi Note 4 Global Display Replacement: step 6, image 1 of 1
    • Remove the rest of the screws
    • Gently pry off the plastic covers
  7. Redmi Note 4 Global Display Replacement: step 7, image 1 of 2 Redmi Note 4 Global Display Replacement: step 7, image 2 of 2
    • Remove the plastic cover from the top of the phone
    • Gentle prying may be help to loosen it.
    • Remove the screw hidden under the cover.
  8. Redmi Note 4 Global Display Replacement: step 8, image 1 of 2 Redmi Note 4 Global Display Replacement: step 8, image 2 of 2
    • Move the plastic tab to the side to remove the main board
  9. Redmi Note 4 Global Display Replacement: step 9, image 1 of 2 Redmi Note 4 Global Display Replacement: step 9, image 2 of 2
    • Disconnect the ribbon cable
    • Remove the screw.
    • Carefully remove the circuit board
  10. Redmi Note 4 Global Display Replacement: step 10, image 1 of 2 Redmi Note 4 Global Display Replacement: step 10, image 2 of 2
    • Gently separate the side button bar from the frame
  11. Redmi Note 4 Global Display Replacement: step 11, image 1 of 2 Redmi Note 4 Global Display Replacement: step 11, image 2 of 2
    • Remove the upper speaker
    • Caution: When removing the speaker, the two parts of the speaker can separate from each other. They are only held together by two very thin copper cables!
    • The best way to get to the bottom of the speaker and pry it out carefully is by using the direction of the red arrow.
  12. Redmi Note 4 Global Display Replacement: step 12, image 1 of 2 Redmi Note 4 Global Display Replacement: step 12, image 2 of 2
    • Peel off the two battery adhesive strips to remove the battery
    • Pull as flat as possible and rather slowly. Heating the display with a hair dryer makes the whole thing a little easier.
  13. Redmi Note 4 Global Display Replacement: step 13, image 1 of 1
    • Disconnect the ribbon cable for the charging board. Keep it safe for later reuse.
  14. Redmi Note 4 Global Display Replacement: step 14, image 1 of 2 Redmi Note 4 Global Display Replacement: step 14, image 2 of 2
    • Depending on the completeness of the replacement part, the LED lighting may also be removed
    • T o remove it, gently pry with some pointed tweezers or similar tool
  15. Redmi Note 4 Global Display Replacement, First Test: step 15, image 1 of 2 Redmi Note 4 Global Display Replacement, First Test: step 15, image 2 of 2
    • For testing purposes, the button bar, the screen and the battery can be connected.
    • Attention! When doing so, there is an increased risk of damaging the connections or the battery. Be very careful!
    • A long press on the bottom button should start the phone
  16. Redmi Note 4 Global Display Replacement: step 16, image 1 of 1
    • Insert the upper speaker and press it into the end position
  17. Redmi Note 4 Global Display Replacement: step 17, image 1 of 1
    • If previously removed, insert the LED bar (red circle)
    • Insert the charging board into proper position and tighten (blue circle)
  18. Redmi Note 4 Global Display Replacement: step 18, image 1 of 1
    • Remove the blue protective strip from the corresponding adhesive surface. Insert the ribbon cable into the power supply
    • Press the cable flat onto the adhesive area
    • Ensure everything is properly aligned
  19. Redmi Note 4 Global Display Replacement: step 19, image 1 of 1
    • Install the lower plastic cover and screw it in place
  20. Redmi Note 4 Global Display Replacement: step 20, image 1 of 3 Redmi Note 4 Global Display Replacement: step 20, image 2 of 3 Redmi Note 4 Global Display Replacement: step 20, image 3 of 3
    • Insert the motherboard
    • Use the metal pin and the plastic hook to check proper alignment.
  21. Redmi Note 4 Global Display Replacement: step 21, image 1 of 1
    • Reconnect all connectors
  22. Redmi Note 4 Global Display Replacement, Replacing the battery: step 22, image 1 of 2 Redmi Note 4 Global Display Replacement, Replacing the battery: step 22, image 2 of 2
    • Remove the cover from the two adhesive strips for the battery
    • Insert the battery and reconnect it.
  23. Redmi Note 4 Global Display Replacement: step 23, image 1 of 1
    • Press the fingerprint scanner back into its position.
    • Press the display back into the housing. Done!
Repeat the steps in reverse order to reassemble your device.
4 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Frederic
457 Reputation
1 Guide authored
3 Comments
There are major steps missing between step 14 and step 15. This is not a complete guide on screen replacement.
Don - Reply
Hi Don, which steps are you missing between 14 and 15 ? Once all parts are removed from the old display one can try the test fit on the new display.
Frederic - Reply
Watch and pray ,global warming.
Jerry Scott - Reply
Past 24 Hours: 1
Past 7 Days: 29
Past 30 Days: 152
All Time: 5,995
