Rear Cameras Removal
View statistics:
Past 24 Hours:
0
Past 7 Days:
8
Past 30 Days:
16
All Time:
213
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prerequisite guide for removing the rear cameras in the Samsung Galaxy S24 Ultra.
Tools
    1. Rear Cameras Removal, Prepare your phone for disassembly: step 1, image 1 of 2 Rear Cameras Removal, Prepare your phone for disassembly: step 1, image 2 of 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard. If your battery is swollen, take appropriate precautions.
      • Unplug any cables from your phone.
      • Hold the side key and the volume down button, then select "Power off" to turn off your phone.
      Ask FixBot
    1. Rear Cameras Removal, Heat the right edge: step 2, image 1 of 1
      • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
      • You may use a hair dryer, heat gun, or hot plate instead, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
      Ask FixBot
    2. Rear Cameras Removal, Insert an opening pick: step 3, image 1 of 3 Rear Cameras Removal, Insert an opening pick: step 3, image 2 of 3 Rear Cameras Removal, Insert an opening pick: step 3, image 3 of 3
      • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
      • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
      • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap.
      Ask FixBot
    3. Rear Cameras Removal, Separate the right adhesive: step 4, image 1 of 3 Rear Cameras Removal, Separate the right adhesive: step 4, image 2 of 3 Rear Cameras Removal, Separate the right adhesive: step 4, image 3 of 3
      • Slide the pick back and forth along the right edge to separate the adhesive.
      • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
      Ask FixBot
    4. Rear Cameras Removal, Heat the bottom edge: step 5, image 1 of 1
      • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
      Ask FixBot
    5. Rear Cameras Removal, Separate the bottom adhesive: step 6, image 1 of 3 Rear Cameras Removal, Separate the bottom adhesive: step 6, image 2 of 3 Rear Cameras Removal, Separate the bottom adhesive: step 6, image 3 of 3
      • Insert a second opening pick next to the first one, near the bottom of the right edge.
      • Rotate the opening pick around the bottom right corner to separate the adhesive.
      Ask FixBot
    6. Rear Cameras Removal: step 7, image 1 of 2 Rear Cameras Removal: step 7, image 2 of 2
      • Slide the opening pick along the bottom edge to separate the adhesive.
      • Leave the pick inserted near the bottom left corner to prevent the adhesive from resealing.
      Ask FixBot
    7. Rear Cameras Removal, Heat the left edge: step 8, image 1 of 1
      • Apply a heated iOpener to the left edge of the back cover for two minutes.
      Ask FixBot
    8. Rear Cameras Removal, Separate the left adhesive: step 9, image 1 of 3 Rear Cameras Removal, Separate the left adhesive: step 9, image 2 of 3 Rear Cameras Removal, Separate the left adhesive: step 9, image 3 of 3
      • Insert a third opening pick next to the second one, near the left side of the bottom edge.
      • Rotate the opening pick around the bottom left corner to separate the adhesive.
      Ask FixBot
    9. Rear Cameras Removal: step 10, image 1 of 2 Rear Cameras Removal: step 10, image 2 of 2
      • Slide your opening pick along the left edge to separate the adhesive, stopping before you reach the power button.
      • Do not insert the pick more than 4 mm to avoid damaging the antenna cable.
      • Leave the pick inserted near the power button to prevent the adhesive from resealing.
      Ask FixBot
    10. Rear Cameras Removal, Heat the top edge: step 11, image 1 of 1
      • Apply a heated iOpener to the top edge of the back cover for two minutes.
      Ask FixBot
    11. Rear Cameras Removal, Separate the top adhesive: step 12, image 1 of 3 Rear Cameras Removal, Separate the top adhesive: step 12, image 2 of 3 Rear Cameras Removal, Separate the top adhesive: step 12, image 3 of 3
      • Insert an opening pick in the gap at the top of the right edge.
      • Rotate the opening pick around the top right corner to separate the adhesive.
      Ask FixBot
    12. Rear Cameras Removal: step 13, image 1 of 2 Rear Cameras Removal: step 13, image 2 of 2
      • Slide the pick along the top edge to separate the adhesive.
      • Do not insert the pick more than 4 mm to avoid damaging the sensor or camera near the top edge.
      Ask FixBot
    13. Rear Cameras Removal, Separate the remaining adhesive: step 14, image 1 of 3 Rear Cameras Removal, Separate the remaining adhesive: step 14, image 2 of 3 Rear Cameras Removal, Separate the remaining adhesive: step 14, image 3 of 3
      • Slide the pick around the top left corner and down the left edge to separate the remaining adhesive.
      • Do not insert the pick more than 4 mm to avoid damaging the cameras.
      Ask FixBot
    14. Rear Cameras Removal, Remove the back cover: step 15, image 1 of 2 Rear Cameras Removal, Remove the back cover: step 15, image 2 of 2
      • Grab and remove the back cover.
      • If your cover is still sticking to the frame, slide an opening pick around the edges to separate any adhesive that may have resealed.
      • During reassembly:
      • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
      • If you're using custom-cut adhesives, follow this guide.
      • If you're using double-sided tape, follow this guide.
      Ask FixBot
    1. Rear Cameras Removal, Disconnect the wireless charging coil: step 16, image 1 of 2 Rear Cameras Removal, Disconnect the wireless charging coil: step 16, image 2 of 2
      • Use a spudger to pry up and disconnect the wireless charging coil press connector from the motherboard.
      • There's an arrow printed on the board near each press connector that indicates the recommended prying location. Only pry in this location for each press connector to avoid dislodging surface-mounted components.
      • To reconnect press connectors, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    2. Rear Cameras Removal, Remove the wireless charging coil and loudspeaker screws: step 17, image 1 of 2 Rear Cameras Removal, Remove the wireless charging coil and loudspeaker screws: step 17, image 2 of 2
      • Use a Phillips screwdriver to remove the ten 3.5 mm‑long screws securing the wireless charging coil and the loudspeaker:
      • Four screws securing the wireless charging coil
      • Six screws securing the loudspeaker
      Ask FixBot
    3. Rear Cameras Removal, Separate the coil adhesive: step 18, image 1 of 2 Rear Cameras Removal, Separate the coil adhesive: step 18, image 2 of 2
      • Use a spudger to gently pry up a corner of the tab of the wireless charging coil that's adhered to the right edge of the frame.
      Ask FixBot
    4. Rear Cameras Removal: step 19, image 1 of 2 Rear Cameras Removal: step 19, image 2 of 2
      • Use an opening pick to separate the tab from the frame.
      Ask FixBot
    5. Rear Cameras Removal, Remove the wireless charging coil and loudspeaker: step 20, image 1 of 2 Rear Cameras Removal, Remove the wireless charging coil and loudspeaker: step 20, image 2 of 2
      • Insert the point of a spudger into the gap between the right edge of the loudspeaker and the frame.
      • There's an arrow engraved in the loudspeaker to indicate the recommended prying location.
      • Pry up to unclip the loudspeaker from the frame.
      Ask FixBot
    6. Rear Cameras Removal: step 21, image 1 of 2 Rear Cameras Removal: step 21, image 2 of 2
      • Remove the wireless charging coil and loudspeaker from the frame.
      • During reassembly, press around the edges of the loudspeaker to clip it to the frame before reinserting the screws.
      Ask FixBot
    1. Rear Cameras Removal, Disconnect the battery: step 22, image 1 of 2 Rear Cameras Removal, Disconnect the battery: step 22, image 2 of 2
      • Use a spudger to pry up and disconnect the battery press connector.
      Ask FixBot
    1. Rear Cameras Removal, Disconnect the interconnect cables: step 23, image 1 of 3 Rear Cameras Removal, Disconnect the interconnect cables: step 23, image 2 of 3 Rear Cameras Removal, Disconnect the interconnect cables: step 23, image 3 of 3
      • Use a spudger to pry up and disconnect both interconnect cable press connectors from the motherboard.
      Ask FixBot
    2. Rear Cameras Removal: step 24, image 1 of 3 Rear Cameras Removal: step 24, image 2 of 3 Rear Cameras Removal: step 24, image 3 of 3
      • Use a spudger to pry up and disconnect both interconnect cable press connectors from the daughterboard.
      Ask FixBot
    3. Rear Cameras Removal, Remove the interconnect cables: step 25, image 1 of 2 Rear Cameras Removal, Remove the interconnect cables: step 25, image 2 of 2
      • Grab and remove the interconnect cables from the phone.
      Ask FixBot
    1. Rear Cameras Removal, Disconnect the earpiece speaker: step 26, image 1 of 2 Rear Cameras Removal, Disconnect the earpiece speaker: step 26, image 2 of 2
      • Use a spudger to pry up and disconnect the earpiece speaker press connector.
      Ask FixBot
    2. Rear Cameras Removal, Remove the earpiece speaker screws: step 27, image 1 of 1
      • Use a Phillips screwdriver to remove the five 3.5 mm‑long screws securing the earpiece speaker.
      Ask FixBot
    3. Rear Cameras Removal, Remove the earpiece speaker: step 28, image 1 of 3 Rear Cameras Removal, Remove the earpiece speaker: step 28, image 2 of 3 Rear Cameras Removal, Remove the earpiece speaker: step 28, image 3 of 3
      • Insert the pointed end of a spudger under the bottom edge of the earpiece speaker, under the engraved arrow.
      • Pry up with the spudger to unclip the speaker and remove it.
      • During reassembly, insert the top edge of the earpiece speaker into the frame first before pressing down and clipping it back in.
      Ask FixBot
    1. Rear Cameras Removal, Remove the display cable: step 29, image 1 of 2 Rear Cameras Removal, Remove the display cable: step 29, image 2 of 2
      • Use a spudger to pry up and disconnect the display cable press connector from the motherboard.
      Ask FixBot
    2. Rear Cameras Removal: step 30, image 1 of 3 Rear Cameras Removal: step 30, image 2 of 3 Rear Cameras Removal: step 30, image 3 of 3
      • Use a spudger to pry up and disconnect the display cable press connector from the daughterboard.
      • Remove the display cable.
      Ask FixBot
    3. Rear Cameras Removal, Disconnect the lower antenna: step 31, image 1 of 2 Rear Cameras Removal, Disconnect the lower antenna: step 31, image 2 of 2
      • Use a spudger to pry up and disconnect the lower antenna press connector from the motherboard.
      Ask FixBot
    4. Rear Cameras Removal, Disconnect the stylus port: step 32, image 1 of 2 Rear Cameras Removal, Disconnect the stylus port: step 32, image 2 of 2
      • Use a spudger to pry up and disconnect the stylus port press connector from the motherboard.
      Ask FixBot
    5. Rear Cameras Removal, Disconnect the upper antenna: step 33, image 1 of 2 Rear Cameras Removal, Disconnect the upper antenna: step 33, image 2 of 2
      • Use a spudger to pry up and disconnect the upper antenna press connector from the motherboard.
      Ask FixBot
    6. Rear Cameras Removal, Disconnect the fingerprint scanner: step 34, image 1 of 2 Rear Cameras Removal, Disconnect the fingerprint scanner: step 34, image 2 of 2
      • Use a spudger to pry up and disconnect the fingerprint scanner press connector from the motherboard.
      Ask FixBot
    7. Rear Cameras Removal, Disconnect the front camera: step 35, image 1 of 2 Rear Cameras Removal, Disconnect the front camera: step 35, image 2 of 2
      • Use a spudger to pry up and disconnect the front camera press connector from the motherboard.
      Ask FixBot
    8. Rear Cameras Removal, Remove the motherboard screws: step 36, image 1 of 1
      • Use a Phillips screwdriver to remove the two screws securing the motherboard:
      • One 4.0 mm-long screw to the left of the top camera.
      • One 3.5 mm-long screw to the left of the bottom camera.
      Ask FixBot
    9. Rear Cameras Removal, Remove the motherboard: step 37, image 1 of 3 Rear Cameras Removal, Remove the motherboard: step 37, image 2 of 3 Rear Cameras Removal, Remove the motherboard: step 37, image 3 of 3
      • Use your finger or a spudger to lift the top of the motherboard.
      • Remove the motherboard.
      • Be careful not to catch on any loose cables.
      • During reassembly, be sure all press connectors are above the motherboard when reinserting it.
      Ask FixBot
    1. Rear Cameras Removal, Disconnect the rear cameras: step 38, image 1 of 2 Rear Cameras Removal, Disconnect the rear cameras: step 38, image 2 of 2
      • Flip over the motherboard to expose the rear camera press connectors.
      • Use a spudger to pry up and disconnect the primary telephoto camera press connector.
      Ask FixBot
    2. Rear Cameras Removal: step 39, image 1 of 2 Rear Cameras Removal: step 39, image 2 of 2
      • Use a spudger to pry up and disconnect the secondary telephoto camera press connector.
      Ask FixBot
    3. Rear Cameras Removal: step 40, image 1 of 2 Rear Cameras Removal: step 40, image 2 of 2
      • Use a spudger to pry up and disconnect the main camera press connector.
      Ask FixBot
    4. Rear Cameras Removal: step 41, image 1 of 2 Rear Cameras Removal: step 41, image 2 of 2
      • Use a spudger to pry up and disconnect the ultrawide camera press connector.
      Ask FixBot
Spencer Pennington
27,662 Reputation
125 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,132 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 16
All Time: 213
