Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓This is a replacement guide for the mouse click back buttons on a Razer Wolverine V3 Pro Wireless controller. This controller may also be referred to as the Wolverine V3 Pro or Razer Wolverine Series controller.
Important Safety Information:
- Disconnect the controller from any power source before starting to avoid electrical damage.
- Handle internal components gently to avoid further damage.
- Even though the removal of the entire outer shell is shown, you only need to remove the 10 screws to gain access to the back buttons.
Tools
Insert the end of a spudger or opening tool in the seam at the top of the controller.
Slide it around the edge to release the retaining clips.
Use the spudger to separate the front and back plastic outer shell of the controller.
Flip the controller so the bottom is facing up.
Use the spudger to separate the plastic covering on the hand grips.
Use a JIS #0 screwdriver to remove 8 screws (4 on each side).
Unhook and push the old buttons out of the button openings in the controller shell.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
