Razer Naga V2 Hyperspeed Programmable Button Panel Replacement
    1. Razer Naga V2 Hyperspeed Programmable Button Panel Replacement, Programmable Button Panel: step 1, image 1 of 3 Razer Naga V2 Hyperspeed Programmable Button Panel Replacement, Programmable Button Panel: step 1, image 2 of 3 Razer Naga V2 Hyperspeed Programmable Button Panel Replacement, Programmable Button Panel: step 1, image 3 of 3
      • Take off the top panel and remove the dongle.
      Ask FixBot
    2. Razer Naga V2 Hyperspeed Programmable Button Panel Replacement: step 2, image 1 of 3 Razer Naga V2 Hyperspeed Programmable Button Panel Replacement: step 2, image 2 of 3 Razer Naga V2 Hyperspeed Programmable Button Panel Replacement: step 2, image 3 of 3
      • Heat the mouse feet and remove them with an opening tool or pick.
      • Reapply adhesive to the feet before reinstallation if you're reusing them.
      Ask FixBot
    3. Razer Naga V2 Hyperspeed Programmable Button Panel Replacement: step 3, image 1 of 1
      • Use a T6 Torx screwdriver four screws on the underside of the mouse.
      Ask FixBot
    4. Razer Naga V2 Hyperspeed Programmable Button Panel Replacement: step 4, image 1 of 3 Razer Naga V2 Hyperspeed Programmable Button Panel Replacement: step 4, image 2 of 3 Razer Naga V2 Hyperspeed Programmable Button Panel Replacement: step 4, image 3 of 3
      • Use the iFixit Opening tool to help remove the top middle part as well as the right side.
      Ask FixBot
    5. Razer Naga V2 Hyperspeed Programmable Button Panel Replacement: step 5, image 1 of 2 Razer Naga V2 Hyperspeed Programmable Button Panel Replacement: step 5, image 2 of 2
      • While taking off the middle shell, carefully disconnect the battery compartment connector.
      Ask FixBot
    6. Razer Naga V2 Hyperspeed Programmable Button Panel Replacement: step 6, image 1 of 1
      • Disconnect the programmable button panel connector.
      Ask FixBot
    7. Razer Naga V2 Hyperspeed Programmable Button Panel Replacement: step 7, image 1 of 3 Razer Naga V2 Hyperspeed Programmable Button Panel Replacement: step 7, image 2 of 3 Razer Naga V2 Hyperspeed Programmable Button Panel Replacement: step 7, image 3 of 3
      • On the left panel remove the four 3 mm-long Phillips screws on the button panel.
      Ask FixBot
    8. Razer Naga V2 Hyperspeed Programmable Button Panel Replacement: step 8, image 1 of 2 Razer Naga V2 Hyperspeed Programmable Button Panel Replacement: step 8, image 2 of 2
      • Use the iFixit opening tool to pry the circuit module off and carefully remove the circuit module with precision tweezers (dull).
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 other people completed this guide.
3 Guide Comments
What micro switch does it use? I need to replace all those in my razer. I need the mm measurements.
Edwin Baruc Morales Zambrano - Reply Share
how does the last part separate? what is the purpose of cleaning the buttons, if you leave them stuck together with coca-cola? You stopped at the hardest part. is this because you also could not separate them ? do they break if you go further? logic? sticking buttons. leave them together, makes sense i get it you now go buy a real mouse that is the lesson. very well done. I have learned my lesson. buy better. Thank you oh wise ones
JasenFromBoston - Reply Share
confusions say disassemble so no one else must suffer. then Danielson, buy better!
Past 24 Hours: 11
Past 7 Days: 48
Past 30 Days: 198
All Time: 995
