Razer DeathStalker V2 Pro TKL Keycap Replacement Guide
    1. Razer DeathStalker V2 Pro TKL Keycap Replacement Guide, Individual key: step 1, image 1 of 1
      • Before beginning the repair, power off the keyboard and disconnect it from the charger and any connected devices.
      Ask FixBot
    2. Razer DeathStalker V2 Pro TKL Keycap Replacement Guide: step 2, image 1 of 2 Razer DeathStalker V2 Pro TKL Keycap Replacement Guide: step 2, image 2 of 2
      • Place your fingers gently on both sides of the keycap. Pull upward slowly and evenly with light pressure before the keycap pops free.
      • A keycap puller can also be used.
      • Try not to twist the keys, because this could damage the low-profile mounting clips underneath.
      • Before you replace the keycaps, use a dust blower to remove loose dust and a cotton swab dampened with isopropyl alcohol to clean the area.
      • When replacing the keycaps, ensure they align with the switch stem before pressing down to avoid damage to the keycap and switch.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Dominic Rodriguez
135 Reputation
1 Guide authored
Texas Tech, Team 11-1, Weston Spring 2026 Member of Texas Tech, Team 11-1, Weston Spring 2026
TTU-WESTON-S26S11G1
5 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 47
Past 30 Days: 125
All Time: 363
