Razer Blade Stealth 2017 Battery Replacement
  1. Razer Blade Stealth 2017 Battery Replacement, Battery: step 1, image 1 of 2 Razer Blade Stealth 2017 Battery Replacement, Battery: step 1, image 2 of 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Battery Replacement: step 2, image 1 of 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Battery Replacement: step 3, image 1 of 2 Razer Blade Stealth 2017 Battery Replacement: step 3, image 2 of 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Battery Replacement: step 4, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Battery Replacement: step 5, image 1 of 2 Razer Blade Stealth 2017 Battery Replacement: step 5, image 2 of 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
14 other people completed this guide.
Ethan Schlocker
347 Reputation
1 Guide authored
Cal Poly, Team S11-G3, Regan Fall 2019 Member of Cal Poly, Team S11-G3, Regan Fall 2019
CPSU-REGAN-F19S11G3
4 Members
7 Guides authored
One Comment
ive done everything correctly and laptop boots up but now I have no battery percentage information. any solutions on how to fix?
fdf - Reply
Past 24 Hours: 7
Past 7 Days: 26
Past 30 Days: 138
All Time: 16,523
