Introduction
Wheels not working properly? Follow this guide for steps on how to replace the wheel system on a RYDIS H68 Pro.
Flip the vacuum over so that the wheels are facing you.
Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
Remove the 10mm Phillips #1 screw securing the spring.
Then undo the spring from the plastic hook to completely remove it from the wheel assembly.
Lift up on the top cover to remove it.
Removing the top cover reveals the gear system consisting of three gears.
