RYDIS H68 Pro Wheel Replacement
  1. RYDIS H68 Pro Wheel  Replacement, Battery: step 1, image 1 of 2 RYDIS H68 Pro Wheel  Replacement, Battery: step 1, image 2 of 2
    • Flip the vacuum over so that the wheels are facing you.
    • Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
  2. RYDIS H68 Pro Wheel  Replacement: step 2, image 1 of 1
    • Lift the battery cover up to reveal the battery.
    • Remove the battery.
  3. RYDIS H68 Pro Wheel  Replacement, Bumper: step 3, image 1 of 3 RYDIS H68 Pro Wheel  Replacement, Bumper: step 3, image 2 of 3 RYDIS H68 Pro Wheel  Replacement, Bumper: step 3, image 3 of 3
    • Remove the eight 10 mm Phillips #1 screws.
  4. RYDIS H68 Pro Wheel  Replacement: step 4, image 1 of 3 RYDIS H68 Pro Wheel  Replacement: step 4, image 2 of 3 RYDIS H68 Pro Wheel  Replacement: step 4, image 3 of 3
    • Hold the front bumper and pull it off.
    • It requires a lot of force to pull the bumper off.
  5. RYDIS H68 Pro Wheel  Replacement: step 5, image 1 of 3 RYDIS H68 Pro Wheel  Replacement: step 5, image 2 of 3 RYDIS H68 Pro Wheel  Replacement: step 5, image 3 of 3
    • Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
  6. RYDIS H68 Pro Wheel  Replacement, Wheel assembly: step 6, image 1 of 1
    • Remove three 10mm Philips #1 screws that are securing the wheel assembly.
  7. RYDIS H68 Pro Wheel  Replacement: step 7, image 1 of 2 RYDIS H68 Pro Wheel  Replacement: step 7, image 2 of 2
    • Remove the 10mm Phillips #1 screw securing the spring.
    • Then undo the spring from the plastic hook to completely remove it from the wheel assembly.
  8. RYDIS H68 Pro Wheel  Replacement: step 8, image 1 of 3 RYDIS H68 Pro Wheel  Replacement: step 8, image 2 of 3 RYDIS H68 Pro Wheel  Replacement: step 8, image 3 of 3
    • Lift up on the plastic piece to remove the entire wheel assembly.
  9. RYDIS H68 Pro Wheel  Replacement: step 9, image 1 of 3 RYDIS H68 Pro Wheel  Replacement: step 9, image 2 of 3 RYDIS H68 Pro Wheel  Replacement: step 9, image 3 of 3
    • Remove the plastic frame by pulling outward on the two spots where it is fastened.
  10. RYDIS H68 Pro Wheel  Replacement: step 10, image 1 of 2 RYDIS H68 Pro Wheel  Replacement: step 10, image 2 of 2
    • Remove the four 10mm Phillips #1 screws around the edges of the cover.
  11. RYDIS H68 Pro Wheel  Replacement: step 11, image 1 of 3 RYDIS H68 Pro Wheel  Replacement: step 11, image 2 of 3 RYDIS H68 Pro Wheel  Replacement: step 11, image 3 of 3
    • Lift up on the top cover to remove it.
    • Removing the top cover reveals the gear system consisting of three gears.
Shawn O'Meara
101 Reputation
1 Guide authored
USFT-Lacy-S17S005G2 Member of USFT-Lacy-S17S005G2
Repair Café
4 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 385
