Punkt MP02 Speaker Replacement
    1. Punkt MP02 Speaker Replacement, Battery: step 1, image 1 of 2 Punkt MP02 Speaker Replacement, Battery: step 1, image 2 of 2
      • Use a SIM card eject tool to to eject and remove the SIM card tray on the side of the phone.
      Ask FixBot
    2. Punkt MP02 Speaker Replacement: step 2, image 1 of 2 Punkt MP02 Speaker Replacement: step 2, image 2 of 2
      • The back panel is held on by glue and multiple tabs.
      • Slide a Jimmy into the seam between the back panel and the chassis.
      • Slide the Jimmy around the perimeter to release the back panel, with care not to damage the retaining clips.
      • Clean any old adhesive with a spudger and isopropyl alcohol, then apply new adhesive to the back panel before reinstalling it.
      Ask FixBot
    3. Punkt MP02 Speaker Replacement: step 3, image 1 of 3 Punkt MP02 Speaker Replacement: step 3, image 2 of 3 Punkt MP02 Speaker Replacement: step 3, image 3 of 3
      • Use a Phillips screwdriver to remove the two adjacent 3 mm Phillips screws.
      Ask FixBot
    4. Punkt MP02 Speaker Replacement: step 4, image 1 of 3 Punkt MP02 Speaker Replacement: step 4, image 2 of 3 Punkt MP02 Speaker Replacement: step 4, image 3 of 3
      • Insert a Jimmy into the seam between the front and back case.
      • Slide the Jimmy around the perimeter while prying to separate the front and back case.
      Ask FixBot
    5. Punkt MP02 Speaker Replacement: step 5, image 1 of 2 Punkt MP02 Speaker Replacement: step 5, image 2 of 2
      • Use a spudger to pry up and disconnect the battery press connector.
      • Make sure to pry under the connector itself and not on the board.
      Ask FixBot
    6. Punkt MP02 Speaker Replacement: step 6, image 1 of 2 Punkt MP02 Speaker Replacement: step 6, image 2 of 2
      • Gently pry the battery off with the spudger tool.
      • Take care not to bend, warp, or puncture the battery during removal.
      Ask FixBot
    1. Punkt MP02 Speaker Replacement, Screen: step 7, image 1 of 3 Punkt MP02 Speaker Replacement, Screen: step 7, image 2 of 3 Punkt MP02 Speaker Replacement, Screen: step 7, image 3 of 3
      • Remove the six 3 mm-long Phillips screws located on the board beneath the battery.
      Ask FixBot
    2. Punkt MP02 Speaker Replacement: step 8, image 1 of 3 Punkt MP02 Speaker Replacement: step 8, image 2 of 3 Punkt MP02 Speaker Replacement: step 8, image 3 of 3
      • Remove the antenna coaxial connectors on the board with a spudger by gently prying straight up where they are connected on the board.
      Ask FixBot
    3. Punkt MP02 Speaker Replacement: step 9, image 1 of 3 Punkt MP02 Speaker Replacement: step 9, image 2 of 3 Punkt MP02 Speaker Replacement: step 9, image 3 of 3
      • Flip up the two black locking flaps securing each of the two ribbon cables.
      • Disconnect the two ribbon cables.
      Ask FixBot
    4. Punkt MP02 Speaker Replacement: step 10, image 1 of 2 Punkt MP02 Speaker Replacement: step 10, image 2 of 2
      • Using your thumbs, push the board up so that the clip can slide out of the indent.
      • Use a spudger to gently separate the boards.
      • Ensure that the antennae slide through the holes—do not accidentally pull these off.
      Ask FixBot
    5. Punkt MP02 Speaker Replacement: step 11, image 1 of 3 Punkt MP02 Speaker Replacement: step 11, image 2 of 3 Punkt MP02 Speaker Replacement: step 11, image 3 of 3
      • Use a spudger to lift and disconnect the screen press connector.
      • Make sure to pry up on the edge of the connector, not the board itself.
      • Remove the screen.
      Ask FixBot
    1. Punkt MP02 Speaker Replacement, Speakers: step 12, image 1 of 2 Punkt MP02 Speaker Replacement, Speakers: step 12, image 2 of 2
      • Take the screen display and turn it around to the back side.
      • Remove the speaker from the black rubber framing with the angled tweezers.
      Ask FixBot
    2. Punkt MP02 Speaker Replacement: step 13, image 1 of 2 Punkt MP02 Speaker Replacement: step 13, image 2 of 2
      • Grab the back phone casing and locate the speaker.
      • Remove the speaker from the back phone casing, using the spudger.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Tariq Muhammad
85 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 55
All Time: 202
