Introduction
This guide will show you how to remove the PowerLead Puto PLD003 side panel. Removing the side panel is necessary in order to replace most parts.
With the battery door open, carefully unscrew, counterclockwise all four 5mm Phillips #1 screws.
Rotate the camera so that the underside is facing up.
Remove the four 5mm Phillips #1 screws.
Place the camera on a flat surface with its underside facing you.
Gently pull up on the side panel to remove it from the camera.
