PowerLead Puto PLD003 Side Panel Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
95
All Time:
606
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to remove the PowerLead Puto PLD003 side panel. The removal of the side panel is necessary, in order to, replace most parts.
Tools
    1. PowerLead Puto PLD003 Side Panel Replacement, Side Panel: step 1, image 1 of 1
      • Slide the battery eject button open to release the battery door.
      Ask FixBot
    2. PowerLead Puto PLD003 Side Panel Replacement: step 2, image 1 of 1
      • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
      Ask FixBot
    3. PowerLead Puto PLD003 Side Panel Replacement: step 3, image 1 of 1
      • Rotate the camera so that the underside is facing up.
      • Remove the four 5 mm Phillips #1 screws.
      Ask FixBot
    4. PowerLead Puto PLD003 Side Panel Replacement: step 4, image 1 of 1
      • Place the camera on a flat surface, with its underside facing you.
      • Gently pull up on the side panel to remove it from the camera.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 95
All Time: 606
