Introduction
This guide will show you how to remove the PowerLead Puto PLD003 side panel. Removing the side panel is necessary in order to replace most parts.
With the battery door open, carefully unscrew all four 5mm Phillips #1 screws using the Phillips screw driver.
Place the camera so that the underside is facing up.
Using your Phillips screw driver, carefully remove the four 5mm Phillips #1 screws.
Place the camera on a flat surface with its underside facing you.
Gently pull up on the side panel to remove it from the camera.
