Replacing a PowerBook G4 PRAM Battery
  1. Replacing a PowerBook G4 PRAM Battery, PRAM Battery: step 1, image 1 of 1
    • You will need to remove the PRAM battery assembly from your computer. Refer to our G4 PowerBook guides for how to do that specifically for your computer.
    • Make note of where the positive (+) side connects so to eliminate confusion when you try to install the new battery.
    • There are only two locations where you will need to solder.
  2. Replacing a PowerBook G4 PRAM Battery: step 2, image 1 of 2 Replacing a PowerBook G4 PRAM Battery: step 2, image 2 of 2
    • With a soldering iron, place the tip on the first joint and hold it there until the solder liquefies allowing you to pull the battery's terminal away.
    • The soldering iron is extremely hot so be sure to keep your fingers away from the metal. You also want to make sure you do not touch anything other than the solder on the assembly board.
    • Do the same for the second, soldered joint.
  3. Replacing a PowerBook G4 PRAM Battery: step 3, image 1 of 2 Replacing a PowerBook G4 PRAM Battery: step 3, image 2 of 2
    • With the old battery free from the assembly, you can now install your new one.
    • Again, make note of where the positive (+) side is installed.
  4. Replacing a PowerBook G4 PRAM Battery: step 4, image 1 of 2 Replacing a PowerBook G4 PRAM Battery: step 4, image 2 of 2
    • Place the battery terminal directly on the remaining solder joint.
    • Using the soldering iron, apply pressure until the solder liquefies and joins with the battery terminal
    • It shouldn't take more than 5-7 seconds
    • Do the same thing for the other soldering joint and you are done.
iFixit Member of iFixit
Staff
135 Members
17,228 Guides authored
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 119
All Time: 38,969
